Re: Unix Shell Script: su command help
try with sudo command. this will execute the command at super user terminal and comes back to user terminal.. u need to add users in sudoers file /etc/sudoers, meanwhile u can also try by putting the the job background. using '&' at the end of each command.
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
