okay then ....
im making dynamic sql statement
rmode is a radio button and tmode is a combo box
Private Sub bsearch_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles bsearch.Click
If rmode.Checked = True Then
ElseIf tmode.SelectedIndex = 0 Then
sql = "SELECT * FROM licdata WHERE Mode = '" & tmode.Text & "'"
ElseIf tmode.SelectedIndex = 1 Then
End If
MsgBox("mode")
End If
con.Open()
da = New OleDb.OleDbDataAdapter(sql, con)
da.Fill(ds, "licdb")
con.Close()
datagridresult.DataSource = ds.Tables("licdb").DefaultView
End Sub
im facing a hell of a problem
do u see two if statement
just one get executed
the second one... if i put only second then it gets executed and if only first then nothing gets executed..
WHYYYYYYYYYYYYYYYY????
PS: radiobutton is checked!!
