Old 23-11-2009, 06:12 AM   #1 (permalink)
Default School Computer Project.. searching directories?
Hey,
Im in class 12 right now (read : excuse for my inactivity) and I thought that for my board project, I'd end up making an ebook library, mostly because I really need one. One of the things that I need this program to do is to search/scan the computer for all pdf,lit,txt,doc etc etc files (a la, Mediamonkey or iTunes) and write their names and paths to a file. Now I'm pretty sure I can use normal fstream for the writing bit, but I can't find a function to search the computer- findnext and findfirst (from the turbo c++ help files) don't search sub-directories within the ones that i specify for example if i were to say search C:\ it won't look up C:\docs.
Is there anyway around this?
Our deepest fear is not that we are inadequate Our deepest fear is that we are powerful beyond measure
karmanya is offline
Old 23-11-2009, 01:32 PM   #2 (permalink)
harryneopotter's Avatar
Default Re: School Computer Project.. searching directories?
Write a Function which takes a directory path ("C:\", or C"\Docs") as argument and then scans the directory and get a list of all the subdirectories. Then recursively call the same function for each of the subdirectories found.
this method will do IMO !!
Example Code:
Void search(string path)
..... use ur code to search for subdirectories.....
and then for each of the subdirectories found .....
search(subdirectory);
Posted again:
Example Code:
Wats the Favourite Mathematical Function of DIGIT FORUM ????
Its "A SINE WAVE" constant
Y ??
They Both keep going "UP AND DOWN, UP AND DOWN............" !!!!!!!!
Last edited by harryneopotter; 23-11-2009 at 01:33 PM. Reason: Automerged Doublepost
harryneopotter is offline
Old 23-11-2009, 01:56 PM   #3 (permalink)
Section Moderator
gopi_vbboy's Avatar
write a progam to genrate sine wave
gopi_vbboy is offline
Old 24-11-2009, 09:09 PM   #4 (permalink)
@harryneopotter Erm, how exactly do i scan for directories? Since find_next and find_first don't even pick them up.
karmanya is offline
Old 28-12-2009, 12:27 PM   #5 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
http://www.devarticles.com/c/a/Cplus...n-Cplusplus/2/
this might be of some help. And I recollect there is some funtion by a similar name to what you said.. sorry dont have the access to turbo c manuals currently..
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 28-12-2009, 08:21 PM   #6 (permalink)
I am the Legend.........
Wink Re: School Computer Project.. searching directories?
run command line dir *.txt *.pdf /s >new.txt from c.
a sudoku web app designed using gwt and gae.- http://solvemysudoku.appspot.com
my blog- http://aniketawati.blogspot.com
aniket.awati is offline
CVS (Computer Vision Syndrom) techiways QnA (read only) 9 03-01-2009 04:27 PM
Using Notebook as Wireless router INS-ANI Tutorials 18 26-11-2008 09:54 AM
HOW TO - Boot up Windows XP 60 times faster! vaibhavtek Tutorials 31 09-01-2008 01:55 PM
VIrus aaaaaaaaa tushar_novice Software Q&A 25 04-01-2005 04:32 PM
Bizzy's Guide to Good Hard Drive Maintenance bizzyboy QnA (read only) 3 29-12-2004 09:50 PM
