Old 25-06-2009, 10:38 AM   #1 (permalink)
bukaida's Avatar
Default a variable number of inputs using JAVASCRIPT for PHP to insert MYSQL
First let me start out by saying I am a beginner so I apologize in
advance if what I ask is too fundamental.
I am accessing a MYSQL database through a web browser and I am
entering data into data tables using PHP.
The problem I am facing is that the number of input rows on the web
page is not fixed and will vary each time. Someone suggested I use
Javascript and that is why I am here now.
Here is an example of the rows that I would like to be able to fill :
Say for
record 1(Persons living in canada)
id name address
1 john canada
2 Jim canada
3 smith canada
record 2(Persons living in LA)
id name address
1 joe LA
2 mathew LA
I have to design an insert form with textbox which will allow me to insert variable number of records in the table(probably giving an option at the begining,to specify how many records). I am using php 4.4 and mysql 5.1. Please help.
Desktop: P-IV 2.4GHz, 512MB DDR, 865GBF Mother Board,
G-Force 5200FX, 17" Samsung flat, WinXp with SP2,
Kaspersky Internet Security 2009.
Laptop:LENOVO 3000 C100 D7 lappy with 2GB DDR2.
bukaida is offline
Old 05-07-2009, 01:20 PM   #2 (permalink)
adatapost's Avatar
Default Re: a variable number of inputs using JAVASCRIPT for PHP to insert MYSQL
create a form for each record.
adatapost is offline
Old 07-07-2009, 03:09 PM   #3 (permalink)
bukaida's Avatar
How will you know in advance about your data?
bukaida is offline
Old 08-07-2009, 11:23 PM   #4 (permalink)
Searching for Anti-Matter
Power_user_EX's Avatar
plz explain ur problem a bit more.
Q6600 @ 3.8Ghz , Sapphire HD6950 2GB @ 920/1370 , 4GB DDR2 Corsair DHX , Razor DeathAdder , Corsair HX 850 ... and what else ...
Power_user_EX is offline
Old 01-10-2009, 04:44 PM   #5 (permalink)
Super Moderator
asingh's Avatar
Is it a data entry form..or a display form..?? That has to have dynamic rows..??
asingh is online now
Old 18-10-2009, 04:08 PM   #6 (permalink)
just make fix the max number of columns in tables for address
Eg
id
Name
Age
Add1
Add2(Nullable)
Add3(Nullable)
Add4(Nullable)
if a person has more than a single line u can fill it up
lucifer_is_back is offline
Old 22-10-2009, 02:15 PM   #7 (permalink)
ramprasad's Avatar
Have a drop down box at the beginning of the page to capture the number of records u want to add.
On the 'OnSelect' or similar function of that Drop down box, associate a JS which will put the 'Input details' (like Name, Country,etc.) required number of times.
ramprasad is offline
- by gforz
- by soumya
