Old 03-06-2009, 06:28 PM   #1 (permalink)
rajwansh2003's Avatar
Default DOS BOX
How to use DOSBox ?
I do not have much knowledge there are some other software which we can use instead of c
Anupam
rajwansh2003 is offline
Old 03-06-2009, 06:36 PM   #2 (permalink)
Sami Hyypiä, LFC legend
Liverpool_fan's Avatar
Default Re: DOS BOX
DOSBOX? C Compiler? Mate I don't know what you get that from.
The only remote connection I can think regarding that is Dosbox can run the antiquated Turbo C/C++ Compilers.
Anyway for a C compiler. I suggest GCC. (MinGW gcc for Windows). Look at my sig.
Experience true education in Computer Science - http://www.udacity.com | http://www.coursera.org
Read before asking / messaging any moderator for any query: FAQ + answers for new members
Don't use forum for chatting. Visit http://webchat.freenode.net/?channels=krow, enter nick and connect.
Liverpool_fan is offline
Old 03-06-2009, 06:46 PM   #3 (permalink)
<Sparkling Pwnies>
Anorion's Avatar
Default Re: DOS BOX
Once you start it up, you will need to mount the drive with dos software in DosBox.
Do mount <drive name> <path>
so Mount C ~/dosgames should do the trick (assuming you are using linux), its pretty much the same for windows as well.
then
C:
then navigate and run the software.
IDDQD IDKFA
Anorion is online now
Old 03-06-2009, 06:48 PM   #4 (permalink)
Level 96 Headbanger
DeSmOnD dAvId's Avatar
Default Re: DOS BOX
DOSBox is used to run older software which are not supported in newer version of windows. If you are trying to run Turbo C++ 3.0, you will need it.
"Words meant to dwell in darkness shall never see the light of day.
Words can be broken, so can bones. Execute the mandate." :twisted:
Steam : DeathMetal
Garena : death_metal27
My Blog : The Pandemonium
(Latest Post : Where does music come from?)
Guitar gear : GB&A (acoustic), ESP LTD-M50 (New :twisted:), Roland MicroCube Amp.
DeSmOnD dAvId is online now
Old 03-06-2009, 10:52 PM   #5 (permalink)
paroh's Avatar
Default Re: DOS BOX
U can try compatibility mode right click on the application ->properties->compatibility
try different compatibility mode which works for u.
I upload the one method of compatibility mode (video tutorial)
http://rapidshare.com/files/170683115/Turbo_C__.wmv
The Second other method video tutorial uploaded
software Required
DOSBox
http://prdownloads.sourceforge.net/dosbox/DOSBox0.72-win32-installer.exe?download
http://rapidshare.com/files/170693525/Turboc_c___DOSBox_method.wmv
Size 6959 KB
paroh is offline
Old 27-03-2010, 04:27 PM   #6 (permalink)
Default Re: DOS BOX
thanks guys...
Anupam
- by gforz
- by soumya
