Old 24-05-2009, 01:37 PM   #1 (permalink)
Unhappy Problem with Arabic in PDF
hi all.. I have a query which is related to arabic display in pdf... my client requires the data to be shown in arabic... everything works fine except, the arabic characters are displayed from left to right instead of right to left... how can I solve this problem...
I use the crystal report engine available with .NET framework 2.0 to create pdf...
This is the code sample
/* Code to export data set to PDF file using the rpt created */
ReportDocument doc = new ReportDocument();
string fileName = (filePath + "\\Statement.rpt");
doc.Load(fileName);
/* set the datasource of doc as dataset */
doc.SetDataSource(dsReport);
/* set export options */
ExportOptions exportOpts = doc.ExportOptions;
exportOpts.ExportFormatType = ExportFormatType.PortableDocFormat;
/* export as PDF */
doc.ExportToHttpResponse(exportOpts, Context.Response, true, "Statement");
sarincv is offline
Old 25-05-2009, 03:58 AM   #2 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Default Re: Problem with Arabic in PDF
Tried right justification ?
Apple iPad 2 16GB WiFi
MetalheadGautham is online now
Old 25-05-2009, 03:24 PM   #3 (permalink)
I solved the issue.... in that particular field in rpt file, i selected test direction as right to left....
sarincv is offline
Old 26-05-2009, 12:14 PM   #4 (permalink)
The Smaller Bang
Thats what right justification means
Glad your issue was solved
- by gforz
- by soumya
