Old 02-04-2009, 10:32 AM   #1 (permalink)
Debian Gnu/Linux User
Sathish's Avatar
Default which is better for mid-level project ASP.NET or PHP
which is robust and reliable for developing mid-range projects.. like handling 10lakhs data + 35 simultaneous user operation.
asp.net or php...
Living for Learning & Learning for Living
Sathish is offline
Old 02-04-2009, 11:14 AM   #2 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
Default Re: which is better for mid-level project ASP.NET or PHP
I recall a student doing a comparison between both. The thing is I have no idea where his assignment was buried lol. I recall the main points being that if you implement MySQL then with an efficient database design then its suitable for large projects. Further some have a tendency of arguing that the price factor is huge. This is not exactly true since there is affordable ASP.NET hosting plans. All I can say is choose what you are better at. By the way theres a ton of more benefits to using ASP.NET however those are quite easily referrable reading Microsofts documentation or googling.
FilledVoid is offline
Old 03-04-2009, 08:58 AM   #3 (permalink)
Super Hero - Super Powers
n2casey's Avatar
PHP+MySQL can handle that much of data and requests. So don't worry, even TDF is also running on that. Advantage for PHP & MySQL is that it is free but for ASP.NET you need to pay. If you are ready to pay then go for one in which you are efficient.
Minds are like Parachutes :arrow: They work best when open
n2casey is offline
Old 03-04-2009, 09:06 AM   #4 (permalink)
Sathish's Avatar
cost is no bar. im ready to spend more bucks. i want stable and reliable and robustness..so i choose asp.net instead of php..??
Sathish is offline
Old 03-04-2009, 09:12 AM   #5 (permalink)
n2casey's Avatar
Then better to go for ASP.NET, with ASP.NET you can develop faster than PHP and also you will have more flexibility & ease in understanding and development.
n2casey is offline
Old 03-04-2009, 09:20 AM   #6 (permalink)
naughty boy :) :)
mahesh's Avatar
^^^^^ +1...................
Phenom II 550 BE | GA-MA78GM-US2H | 160 gb + 500 gb hdd | 2 X 2 gb XMS2 | HD 4850 1 GB | 2033 SW | Tagan TG600-U37 | CM 690
mahesh is offline
Old 05-04-2009, 11:33 PM   #7 (permalink)
nor asp.net nor php if u want stability and scalability go for java on linux
struts 2, hibernate
or seam
Dhiraj Thakur
thakur.dheeraj(@)gmail.com
Desi-Tek.com is offline
Old 06-04-2009, 11:01 AM   #8 (permalink)
n2casey's Avatar
Smile Re: which is better for mid-level project ASP.NET or PHP
struts 2, hibernate
or seam
Well PHP & ASP.NET both are as stable as Java. So there is no question of stability since it depends on developer whether he is able to develop a stable application or not. To develop application with ASP.NET is easy for beginners as compared to Java or PHP.
n2casey is offline
Old 13-04-2009, 05:09 PM   #9 (permalink)
toofan's Avatar
I would prefer PHP + MySql any day. Its easy to understand and also similar to other programming languages. so no worries understanding basics.
Check my work at:
http://www.flickr.com/photos/vimaljoshi
toofan is offline
Old 13-04-2009, 08:38 PM   #10 (permalink)
Always confused
vamsi360's Avatar
+1
Vamsi Subhash
visit my blog at www.vamsisubhash.co.cc and taste a bit of IT!
vamsi360 is offline
Old 14-04-2009, 06:32 AM   #11 (permalink)
Sathish's Avatar
deciding php&mysql..
Sathish is offline
Old 14-04-2009, 09:24 AM   #12 (permalink)
n2casey's Avatar
ASP.NET is very easy coz it provides lot of things readymade. Also you will find C# much similar to C++ so it's very easy to understand. SQL Server is much better than MySQL in providing friendly environment for development.
@Betruger
Go for one in which you have better understanding. If you know C++ then it's very easy to code in C#.
n2casey is offline
Old 14-04-2009, 08:07 PM   #13 (permalink)
Always confused
vamsi360's Avatar
PHP/MYSQL are opensource so I prefer LAMP to MS tools.
But MS never gives up and i think ASP.net will continue to shine..
Vamsi Subhash
vamsi360 is offline
- by gforz
- by soumya
