Old 27-03-2009, 07:53 PM   #1 (permalink)
Unhappy Basic SQL *Plus Programming for newbies
I am a complete newbie to SQL *Plus programming.Can anyone plz tell me how to learn
basic SQL Plus programming commands like creating tables,processing queries etc.I have seen some books but the information there is either too cluttered or so advanced as not suitable for beginners like me.
arpan sikdar is offline
Old 27-03-2009, 08:49 PM   #2 (permalink)
Back!
red_devil's Avatar
Default Re: Basic SQL *Plus Programming for newbies
try to get hold of DBMS book authored by navathe...its explained in pretty simple way
<btw, just concentrate on it for a few minutes...you'll get the concept real quick>
red_devil is offline
Old 28-03-2009, 02:36 AM   #3 (permalink)
thanks a lot
Last edited by arpan sikdar; 28-03-2009 at 02:40 AM. Reason: Automerged Doublepost
Old 05-04-2009, 08:57 PM   #4 (permalink)
if u are new to sql plus ,then u can refer SUMITA AROARA's 12 class book, that will help u after geeting basics of sql plus, u refer navathe......
just try sumita arora's INFORMATICS PRACTICES
surajkumarjha2002 is offline
Old 06-04-2009, 08:29 PM   #5 (permalink)
The world famous book on sql is by henry f. korth.
read it you will be served better.
Posted again:
Last edited by Champachikla; 06-04-2009 at 08:30 PM. Reason: Automerged Doublepost
Champachikla is offline
- by gforz
- by soumya
