Old 23-03-2009, 09:32 PM   #1 (permalink)
Unhappy Programming in DOS
OK Friends,
A little bit primitive question. I want your suggestions. I downloaded a lot of wallpapers from IndiaFM site through Bulk Image downloader. Now I want to sort it out through Actress/ Actor names and put them in respective folders. I know that it can be done through Cut Paste Option, but I want to do it in DOS. So here I go.
I noticed there filename pattern. For e.g., they start Koena Mitra Wallpapers through koena15.jpg, koena16.jpg, koena17.jpg and so on…
Now I know how to list those files in DOS. I go into the directory and give
This command shows up all the files of Koena Mitra Wallpapers.
But can anyone help me to copy them to KoenaMitra directory in batch mode?
I am uploading the screenshot of my folder where all my files are kept
Waiting for your reply.
Boxer
cooldev007 is offline
Old 24-03-2009, 10:02 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: Programming in DOS
something like:
copy koena*.jpg c:\koenamitra
should work. I cant see your SS so follow up.
dheeraj_kumar is offline
- by gforz
- by soumya
