Old 18-03-2009, 01:09 PM   #1 (permalink)
Default How to save a web page as HTML using PHP
The question is simple i want to save the content of any webpage to simple html so that it can be viewed locally. I can easily get the page content using get_file_content or using curl but the links(a href), scripts and css wont work as they are defined by their relative path in most of the pages. So i wanna to know how to fix those so that the page will work by itself if it is run locally from my system? I suppose they can be fixed using regular expression but i am not very good at regex.
Please Help.
What Is Seen Is Not Always True
jitun is offline
Old 18-03-2009, 01:41 PM   #2 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
Default Re: How to save a web page as HTML using PHP
You will have to use regex to place the <baseurl> and then write the file to disk using fopen and fwrite.
गीक होना माँगता
victor_rambo is offline
- by gforz
- by soumya
