Old 15-03-2009, 11:54 AM   #1 (permalink)
JojoTheDragon's Avatar
Question HTML Help!
Can anyone tell me how to create a image-map so that when i hover the cursor on the specified location and click on it, it takes me to a url?
also please give example codes.
I'm a new learner.
JojoTheDragon is offline
Old 15-03-2009, 01:54 PM   #2 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
Default Re: HTML Help!
http://www.w3schools.com/TAGS/tag_map.asp
गीक होना माँगता
victor_rambo is offline
Old 15-03-2009, 07:11 PM   #3 (permalink)
An Esoteric Geek
sridatta's Avatar
Just for info, You can do this in dreamweaver without having to struggle with co-ordinates.
sridatta is offline
- by gforz
- by soumya
