Old 28-02-2009, 10:24 PM   #1 (permalink)
arian29's Avatar
Arrow need help with the below logic/code
'form2
Private Sub Command1_Click()
Unload Form2
Form3.Show
End Sub
'form3
Unload Form3
Form4.Show
End Sub
Private Sub Form_Load()
Counter = 5
End Sub
Private Sub Timer1_Timer()
Counter = Counter - 1 'we set the counter to count here
Text3.Text = Counter
'If Text3.Text = 0 Then
'MsgBox ("DONE")
'Unload Me
'End If
End Sub
what happens is that "Sub Timer1_Timer()" never execited. the focus goes from the first End Sub in form3 to the End Sub in form2 and thats it, nothing happens. "Private Sub Timer1_Timer()" never executes. need some help here pls..
arian29 is offline
Old 28-02-2009, 11:12 PM   #2 (permalink)
Default Re: need help with the below logic/code
Have you set the timer interval. If yes to what value
silent008 is offline
Old 01-03-2009, 11:25 AM   #3 (permalink)
arian29's Avatar
interval is set to 1000. changed the code to:
'form3
Counter = 5
End Sub
End Sub
now what happens is the the value of "counter" is always 0 in Timer1_Timer() even though it has been initialized to 5 in Form_Load(). so i am getting -1 as the value in counter when i run the code.
arian29 is offline
Old 01-03-2009, 06:58 PM   #4 (permalink)
No doubt the counter has been initialized to 5 in form load, but I think that every second the timer event occurs and counter is decremented so it will have a value of -1 at som point of time.
I am jst trying to help, even i might be wrong
Partition Logic - the free partitioning software Ponmayilal Reviews 9 24-11-2008 06:13 PM
Logic needed... decimal numbers arian29 Programming 8 29-06-2008 09:28 PM
How to get a Seagte HDD logic card 250GB pata longlife Hardware Q&A 1 23-02-2008 09:51 AM
Where I can find drivers for my Avance logic ALS 120 onboard Uma009 QnA (read only) 3 25-08-2004 09:37 AM
- by gforz
- by soumya
