Old 26-02-2009, 07:16 PM   #1 (permalink)
Default shell scripting
Is learning shell scripting in UNIX of any use (besides geekiness) as most of the distros are shipped with gui
and what is the best source for learning shell scripting
sumigizlov is offline
Old 27-02-2009, 09:50 PM   #2 (permalink)
Default Re: shell scripting
Not important for home users but very important for administrators/developers. GUI doesn't give you as much power as CUI
ThinkFree is offline
Old 27-02-2009, 10:18 PM   #3 (permalink)
String Phreak
mediator's Avatar
man bash
mediator is offline
Old 28-02-2009, 06:14 PM   #4 (permalink)
most important thing is that by using shell scripting you can modify th OS suiting to ur needs. Windows gives you pre compiled features, you cannot alter them, even if you need to do so.
But in UNIX n LINUX using shell scripting you can always modify or create any component, feature, or tool in the entire Operating System, what ever you feel like.
So shell scripting is very handy.
gaurarpit is offline
Old 14-03-2009, 09:21 AM   #5 (permalink)
Shell scripting is very useful.. It helps you in making things easier.
Like, if you use gnome environment, then you might be knowing that nautilus doesnt have by default option of "send to".
In that case, if you know shell scripting then you can easily write nautilus-script to add that feature "ALL BY YOURSELF".. This is a very basic example i gave you. Scripting is a lot more powerful..
Abhijeet Rastogi
shadyabhi is offline
Old 14-03-2009, 09:28 AM   #6 (permalink)
Linux User
ghost at rest's Avatar
Check linuxcommand.org first. Move to http://tldp.org/LDP/abs/html/ after that.
ghost at rest is offline
Old 19-03-2009, 05:11 PM   #7 (permalink)
those were good site thank u ghost @ rest...
ajith025 is offline
Linux Shell Scripting - bash: ELF command not found shady_inc Programming 5 13-09-2008 01:35 AM
good book / ebook/link for shell scripting ? esumitkumar Programming 8 26-10-2007 10:45 PM
Good Book on Shell Scripting? paragkalra Open Source 2 07-07-2007 08:05 PM
goto command for shell scripting? paragkalra Open Source 1 24-07-2006 10:33 AM
HELP shell scripting!! mediator Open Source 3 13-08-2005 12:33 AM
- by gforz
- by soumya
