Old 23-02-2009, 01:35 AM   #1 (permalink)
Arrow Python: why it worked later, function keywords:
The following code didn't work:
class X(object):
def f(self, **kwds):
print kwds
try:
print kwds['i'] * 2
except KeyError:
print "unknown keyword argument"
self.g("string", kwds)
def g(self, s, **kwds):
print s
print kwds
if __name__ == "__main__":
x = X()
x.f(k = 2, j = 10)
However the following did:
class X(object):
print kwds
try:
print kwds['i'] * 2
except KeyError:
self.g("string", **kwds)
print s
print kwds
x = X()
x.f(k = 2, j = 10)
Please explain
ravi.xolve is offline
Old 23-02-2009, 08:48 AM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: Python: why it worked later, function keywords:
Its because your g function is set to accept one formal parameter and optional keyword arguments after it. So its set to accept only 2 arguments inside the class, the class itself and s.
In Python, the * is usually used to "unpack" a tuple or a list for passing them as arguments to a function, while the ** is used over dictionaries to make them deliver keyword arguments over to other functions that accept it as the last parameter.
For more, there's Python documentation reference.
Harsh J
www.harshj.com
QwertyManiac is offline
Only Linux distro that actually worked. :P Tech_Wiz Open Source 34 15-12-2007 08:03 PM
Piracy worked for us, Romania president tells Gates anandk Random News 29 07-02-2007 02:49 AM
has anyone worked in powerbuilder technology ? tech_cheetah QnA (read only) 1 24-01-2006 01:48 AM
I found a CALER ID CAPABLE MODEM it worked too but .. vijaythefool Networking 5 30-06-2005 09:04 AM
.:: Correct Way Of Specifying Keywords In Meta Tags? ::. tuXian Software Q&A 13 13-03-2005 06:35 PM
- by gforz
- by soumya
