Old 19-02-2009, 01:19 PM   #1 (permalink)
ruturaj3's Avatar
Default Integer range in C
HI,
In C int is by default, signed short int so it uses 2 bytes(I m talking abt 16 bit compiler). and its range is -32768 to 32767.
And char uses 1 byte.
char ch = 1300, printf("%d",ch); prints 20.
coz, it takes only 8 bits.
1300 = 0101 0001 0100 in binary.
so when storing 1300 in char, it takes only 8 bits ie 0001 0100 wich is +20 (+ coz its signed bit is 0) in decimal.
So int a = 32767, printf("%d",a); prints output correctly ie 32767.
32772 = 1000 0000 0000 0100 in binary.
so if i tak 16 bits and since signed bit is 1 so - sign. so it should print - 4 na.
but int a = 32772, printf("%d",a); prints -32764 why ??? I m not getting tis point only.
ruturaj3 is offline
Old 19-02-2009, 02:31 PM   #2 (permalink)
Canon 1000D
astroutkarsh's Avatar
Default Re: Integer range in C
Its Range Problem.
You have added 5 in 32767 for 32772.
As Range Limit 32768 ==> -32768, 32769 ==> -32767..... 32772 ==> -32764.
At Binary Level try Addition of Two Binary Numbers with 16 bit Limitation.
Binary of 32767 + Binary of 5 (111111111111111 + 101)
Canon 1000D + 18-55 + 50mm f/1.8 + 55-250 IS :-)
astroutkarsh is offline
Old 19-02-2009, 06:16 PM   #3 (permalink)
you have crossed the bit level possible representation in binary mode, form here on each compiler reacts differently..........and if you are talking with respect to turbo c++....the above explanation is true.
Jayanth.M.P is offline
Old 24-02-2009, 09:01 PM   #4 (permalink)
Since negative numbers are stored in 2's complement form
Therefore, 1's complement of 1000 0000 0000 0100 = 0111 1111 1111 1011
2's complement of 1000 0000 0000 0100 = 0111 1111 1111 1100
which is 32764 in decimal.
Since sign bit is set, therefore answer is -32764
And yes, since integer size in C is platform dependent, so answer may be different on different platforms. The answer is same for all 16-bit compilers (not limited to only Turbo C++ 3.0)
grvpuri is offline
Need HTPC configuration ! (Low range / Mid range) blackbird PC Components / Configurations 19 02-04-2009 04:36 PM
Best mobile in the range of 10k to 15K sagarkumar Buying Advice 38 12-02-2009 05:04 PM
Mid Range Motherboard (Under 7k) static_x Hardware Q&A 8 21-11-2008 09:10 PM
Python: How to check integer ? The Unknown Programming 3 27-01-2008 04:29 PM
Best phone in the range 12k khin007 Mobiles and Tablets 30 05-12-2006 01:58 AM
- by gforz
- by soumya
