Old 05-02-2009, 10:39 AM   #1 (permalink)
Lightbulb Shell Programming
I am learning shell programming and I want to run those programs in my some so can any one tell me is there any software or compiler available that run on xp to run shell program or I have to install Linux or Unix operating system.
meghraj is offline
Old 05-02-2009, 11:28 AM   #2 (permalink)
ruturaj3's Avatar
Default Re: Shell Programming
I dont know any software or compiler available that run on xp for shell. But u can use any live cd that comes with digit.
ruturaj3 is offline
Old 05-02-2009, 06:03 PM   #3 (permalink)
Please google cygwin. Your problems should be solved.
RChandan is offline
Old 08-02-2009, 11:27 PM   #4 (permalink)
Smile Re: Shell Programming
buddy, i suggest u to use VMWARE workstation. using that u can isntall a linuz distro parallely to ur XP. and u can check execute all ur shell-scripts in terminal on the linux dat u wud run using VMWARE.
gaurarpit is offline
Old 08-02-2009, 11:34 PM   #5 (permalink)
hahahari's Avatar
^yeah I would actually second that. VMW is very easy to use and I have used it for similar purposes with gr8 success.
www.harivarrier.com
Check out to earn money...
hahahari is offline
Old 08-02-2009, 11:53 PM   #6 (permalink)
thanks buddy for supporting my point..
@topic
VMWARE is very easy to configure and i recommend or rather insist you to use it if u are new to Linux or shell scripting.
Old 09-02-2009, 12:01 AM   #7 (permalink)
Commander in Chief
QwertyManiac's Avatar
Using Cygwin to get a UNIX shell is far better a solution than virtually running an entire OS.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 09-02-2009, 10:38 PM   #8 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
I'm no linux geek, but for practising for my OS lab exams, I used free Sun VirtualBox, together with a free Knoppix live CD.
dheeraj_kumar is offline
Unix(shell Programming) and TCP/IP programming tutorials Matrix Programming 4 08-04-2008 09:54 PM
Shell Picture. LEARNER_LEARNER Software Q&A 1 15-05-2007 07:24 PM
Shell programming ra_sriniketan Programming 4 09-11-2005 11:00 PM
Shell Packs upendra_gp QnA (read only) 3 24-05-2005 12:46 AM
How to do floating point arithmetic in Shell programming? hafees Open Source 2 28-03-2005 12:32 AM
- by gforz
- by soumya
