Old 02-02-2009, 12:14 PM   #1 (permalink)
Excessive happiness
furious_gamer's Avatar
Default AEF Not works in localhost
Hi guys,
Yesterday, i d/l the Advanced Electron Forum, from their site and paste it in my htdocs(I am using XAMPP for running PHP) folder.When i give localhost/aef/ it redirects me to setup page.After filling up all the details and click Submit it seems not working. Yes, the page not loading,Its freezing. So i just click the stop button and click Submit again, it shows an error msg says
Error : aef_apps table already exists
Is the AEF forum wont run in localhost?
If not then let me know whats the problem here?
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
furious_gamer is online now
Old 02-02-2009, 05:12 PM   #2 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
Default Re: AEF Not works in localhost
Can't really make out the problem....I have installed AEF on localhost in the past.
गीक होना माँगता
victor_rambo is offline
Old 02-02-2009, 05:36 PM   #3 (permalink)
Excessive happiness
When i press the Submit button after fill out all the details and install page, it just freezes and nothing happens.So i just close the browser and open in new window, again run the AEF install, it gives the error table already exists.
Ofcourse the tables were been created but not the forum.
PS Request
Old 02-02-2009, 05:47 PM   #4 (permalink)
हॉर्न ओके प्लीज़
Hmmmm....you can try this.
See its installation folder..ther must be a SQL file. Run that SQL file and then manually fill up the DB connection details!
On a side note, why are you installing AEF? I had seen its code and its quite immature. Why don't you go for MyBB(http://www.mybboard.net) instead?
गीक होना माँगता
Old 02-02-2009, 06:52 PM   #5 (permalink)
Excessive happiness
Will give it a try?
And as far as AEF, i like the interface a lot.
PS Request
Old 02-02-2009, 06:57 PM   #6 (permalink)
हॉर्न ओके प्लीज़
^yeah...AEF has a good interface...I remember that revolving dock
गीक होना माँगता
Old 02-02-2009, 06:58 PM   #7 (permalink)
Excessive happiness
By the way hows MyBB. I never used it.Will u give a site which uses MyBB?
PS Request
Old 02-02-2009, 07:26 PM   #8 (permalink)
हॉर्न ओके प्लीज़
hmmm...MyBB is quite nice, infact its close to vB(dont take this too seriously though )
If you want to see a MyBB powered forum, you can see their own forum at http://community.mybboard.net
If you want to see the administration part, then you can install a local copy and check it!
गीक होना माँगता
Old 03-02-2009, 12:43 PM   #9 (permalink)
Excessive happiness
Nice one.Does it the default theme of the forum?
PS Request
Old 03-02-2009, 02:57 PM   #10 (permalink)
हॉर्न ओके प्लीज़
yes, thats the default theme.
गीक होना माँगता
Old 03-02-2009, 02:59 PM   #11 (permalink)
Excessive happiness
Thats cool.. Anyway i am trying installing MyBB currently and inform u later..
PS Request
Fedora Core 7:Localhost login? daemon Open Source 27 08-07-2007 09:17 PM
Fedora Core 6:Localhost login? Cool G5 Open Source 45 28-05-2007 05:31 PM
Localhost........? satyamy QnA (read only) 7 15-04-2007 07:05 PM
403 for Joomla,xoops on Apache localhost desertwind Open Source 11 12-02-2006 02:08 PM
problem accessing localhost niranjan_mcarenyold QnA (read only) 2 30-07-2005 03:09 PM
- by gforz
- by soumya
