i made a project on student's result sheet in c++ for submitting in school.I have wasted lot of time in order to remove that problem and still i m unable to sort it out.The program is running properly but it is giving problem in the ouput.
i have created 7 functions in the program Their work is as follow:
function 1 : MAKE REPORT CARD
2. APPEND NAMES
3. SORT NAMES
4. SEARCH A NAME
5. UPDATE GRADE
6. VIEW REPORT CARD
7. LIST OF FAILURES
8. MAIN MENU
function 1 and 2 are working properly(to add details of students )
rest of the functions are not working properly except the function 7 which displays the list of failures
when i enter values in function 1 and2 it accepts those values. But when i sort names according alphabetically then it displays only those names in the output which were appended by function 2,It gives zero for the values added in function 1
In function 4 of searching also, it doesnt displays anything .Function 6 of viewing report cards is also not working
Can you suggest me what could be the problem in the program I am sending you the program.
