Old 24-01-2009, 02:36 PM   #1 (permalink)
Sridhar_Rao's Avatar
Default What is wrong with this php code?
Hello,
I had created a html page with form in it. I submit the page to say result.php
<form name="poll" action="result.php" method="post" >
For some reasons, nothing was showing up in result.php page. I have checked and confirmed that the form is submitting correct values as they were delivered to my email. The values were not being received well the php page. I found this script in the net which is supposed to help see if the form submission works correctly or not. I changed the line to:
<form name="poll" action="x.php" method="post" >
Here is the content of page x.php
PHP Code:
session_start
echo
"<b>PHP Errors:</b><br><br>";// Displays general PHP errors.
error_reporting(E_ALL);
echo
"<br><br>**********<br><br>";// This section is for checking Session Vars.
echo "<b>Session Values:</b> <pre>";
print_r($_SESSION);
echo
"</pre>";
echo
"<br><br>**********<br><br>";// This section is for checking form submissions.
echo "<b>Post Values:</b><br><br>";
while(list(
$key,$value) = each($HTTP_POST_VARS)) {
        if(
is_array($value)) {
            while(list(
$key2,$value2)=each($value)) {
                echo
"array $key$key2 -> $value2"
                echo
"<br>";
        } else {
            echo
"$key -> $value"
            echo
"<br>";
The page calling this www.microrao.com/opinion.htm. The page gets redirected to x.php but nothing shows up. While google chorme throws up totally blank page, Firefox shows the php script partially.
Please look into this and let me know what the problem is.
Want to study M.Sc in any medical subjects? Read this www.microrao.com/msc.htm
Microx, a diagnostic microbiology laboratory software application www.labmicrox.com
Sridhar_Rao is offline
Old 24-01-2009, 03:55 PM   #2 (permalink)
Default Re: What is wrong with this php code?
Make the first line
<?php
instead of
qprojects is offline
Old 24-01-2009, 04:54 PM   #3 (permalink)
Excessive happiness
furious_gamer's Avatar
^^ No need to do so. That one is short tags and cause no problems. The problem lies with the Web Server. Are you sure your Web Server runs any other PHP pages.Please check that out too.
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
furious_gamer is online now
Old 24-01-2009, 06:11 PM   #4 (permalink)
Yes, php on other page is working fine, take a look at this php page in my site; www.microrao.com/terror_poll.php
I seriously wonder what is causing the problem!
Old 24-01-2009, 08:03 PM   #5 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
The action attribute of your form is wrong, its pointing to "opinion.php" and not "x.php".
If x.php is accessed directly through address bar, I do get what is expected.
If the script is shown partially(if it really does), then you must use PHP complete opening tags, else allow short tags!
गीक होना माँगता
Last edited by victor_rambo; 24-01-2009 at 08:05 PM. Reason: Automerged Doublepost
victor_rambo is offline
Old 24-01-2009, 08:12 PM   #6 (permalink)
Smile Re: What is wrong with this php code?
Thanks for your replies!
I have been trying like mad over the past few hours getting it right. In the process, I have been juggling and changing the lines and links. Sometimes it was x.php, or x2.php or opinion.php. I was modifying codes, adding little by little and tried to determine where exactly was the mistake.
While doing this troubleshooting I came across a simple flaw, I missed a "}" in several of the scripts. Even though error reporting was on, it never got displayed. I fixed it and it now works.
I was looking for you, victor_rambo; are you rohan shenoy by any chance?
Old 24-01-2009, 08:32 PM   #7 (permalink)
sachin_kothari's Avatar
^^ yup, he is.
sachin_kothari is offline
Old 24-01-2009, 09:06 PM   #8 (permalink)
हॉर्न ओके प्लीज़
ya, I am Rohan Shenoy
गीक होना माँगता
Old 29-01-2009, 02:47 PM   #9 (permalink)
hi friends...
its me dhanush... a new comer to ur discussions.....
myself too using php in connection with AJAX.
i wish to use objects in php.....
but i didnt receive any o/p.....
can anyone help me......
thanks in advance
Dhanushkodi is offline
Old 29-01-2009, 04:18 PM   #10 (permalink)
Excessive happiness
Why dont you put your code and what o/p you got here
PS Request
Unable to insert record (what's wrong with php code) Sridhar_Rao Programming 3 05-12-2008 06:49 PM
Whats wrong with this C++ code? zegulas Programming 3 06-03-2008 07:17 PM
lock code..not security code magneticme200 Mobiles and Tablets 3 29-12-2007 07:15 PM
What's wrong with CPU-Z ? mohit CPU / Motherboards 2 11-04-2005 11:44 AM
What's wrong with the cd? callsriram QnA (read only) 14 09-11-2004 07:00 PM
- by gforz
- by soumya
