Old 19-01-2009, 07:16 PM   #1 (permalink)
Question Setting up SVN
I want to manage by codes, so i looked for Version control software and found SVN.
Now, How can I set up the SVN for my local machine (OS : windows). help me!
bapixx2 is offline
Old 19-01-2009, 11:54 PM   #2 (permalink)
ninad_mhatre85's Avatar
Default Re: Setting up SVN
SVN is distributed version control software ..... here is the tortoise SVN which integrates into explorer of windows pretty easy to do simple version control but for advance stuff you got to read man pages.
here is the link http://tortoisesvn.net/
if you want more here is the link on wiki
http://en.wikipedia.org/wiki/List_of...ntrol_software
Life is not measured by moments u breath but by the moments that take ur breath away
ninad_mhatre85 is offline
Old 20-01-2009, 04:45 PM   #3 (permalink)
Err.. what?
BSOD's Avatar
TortoiseSVN is good but, you do need to know some theory so, this might be a good place to start from.
BSOD is offline
Old 20-01-2009, 05:24 PM   #4 (permalink)
Thank for ur help guys!
bapixx2 is offline
Old 26-01-2009, 01:36 PM   #5 (permalink)
I would say not to directly jump into the GUI like Tortoise-SVN and instead do it manually by editing the required config files and the svn command-line binary.... Why you may ask ? You can learn lots this way.... the svn command has lots of options and once you have got a hold of them, you can do magic....
I'm using SVN at my workplace..... Although I'm not a CM (configuration mgmt) person I've done lots of tagging, merging, stuff and so have found the command-line version simple and comprehensive to use..... There is a tool called websvn which is a php based web-ui for your svn repository.... You can use it to monitor check-ins and logs.....
ash25_nofear is offline
Setting up SLi assasin Hardware Q&A 15 08-11-2007 02:18 AM
Setting up IM??? prankie Mobiles and Tablets 7 19-05-2006 10:42 PM
Help 4 setting up New HDD and DVD ROM Thor QnA (read only) 11 30-10-2004 01:43 AM
- by gforz
- by soumya
