02-01-2009, 10:08 PM
learnhardy
problem with c compiler in linux
Hi all,
i am new to linux system.
I am very comfortable with TURBO C or C++........now just i m shifted to dev C++(beta version),geany etc .......in my new linux system .....i have been facing problem with these compilers ......can u guys simplly tell me whts the main difference between these two ........how to set these compilers in linux??
Newbie......
celebrate an ancient art .....
http://ambika.99k.org
02-01-2009, 10:22 PM
Section Moderator
Re: problem with c compiler in linux
google GCC
02-01-2009, 10:36 PM
learnhardy
Originally Posted by gopi_vbboy
google GCC
LOL.
I did googling ........... in ubuntu ,linux forum.........find that there is nothing i am doing wrong.........but i know something is going wrong .......with my compiler.
Newbie......
Reason: Automerged Doublepost
03-01-2009, 12:30 AM
Commander in Chief
Here's a start: C++ in knoppix
Also, since there is no conio.h in Linux, quit using clrscr and getch functions.
Harsh J
www.harshj.com
03-01-2009, 12:34 AM
learnhardy
hey qwerty i m going to leave this forum........
everyone assign me goggling .......if i find it difficult ......and not get .....right one by googling ....then??
Newbie......
03-01-2009, 12:43 AM
Commander in Chief
As you wish.
Give a code sample to help with.
Harsh J
www.harshj.com
03-01-2009, 01:07 AM
learnhardy
Originally Posted by QwertyManiac
As you wish.
u r laughing ?? ......
Newbie......
03-01-2009, 07:19 AM
Always confused
use gcc in terminal.
cc filename.c
./a.out
Why going for IDEs when you are a newbie?
Use terminal and vi editor ......
Vamsi Subhash
visit my blog at www.vamsisubhash.co.cc and taste a bit of IT!
03-01-2009, 07:37 AM
God of Mistakes...
Before that, if you are using Ubuntu, then install build-essentials package by doing-
sudo apt-get install build-essentials
Then you can write your code in vi / gedit / kete as
vi filename.c
gedit filename.c
kete filename.c
After that, you can compile file using-
gcc filename.c -o filename
And now run by -
Hope, this will help.
03-01-2009, 07:54 AM
Always confused
To clear the screen in linux, use system calls :
#include<unistd.h>
system("clear"); //inside any function
Vamsi Subhash
03-01-2009, 04:21 PM
Commander in Chief
You do know that DOS's clear and Linux's clear commands are very different? It might lead to issues based on what one's intending to do. If you want a proper window-like console system, go for ncurses.
Harsh J
www.harshj.com
03-01-2009, 04:35 PM
vi filename.c
gedit filename.c
kete filename.c
What is this Kete...lol
24-01-2009, 09:21 PM
Always confused
that depends on the programmers intension dude
Vamsi Subhash
24-01-2009, 09:30 PM
Commander in Chief
Didn't I use the word if? And to use system("clear") is wrong, you may try it out yourself. It would not work as expected on most terminal emulators of Linux.
Harsh J
www.harshj.com
24-01-2009, 09:54 PM
Sami Hyypiä, LFC legend
I think it sucks pretty much that much of new programmers are trained in anything but Turbo C++.
And to add to that, they are made to use, clrscr(); gets() and void main().
Duh...
And a new programmer doesn't even understand.
@OP:
Look here but some tips:
http://home.att.net/~jackklein/ctips01.html
25-01-2009, 12:13 PM
Always confused
@qwerty
if it is a problem in other emulators ok ....agreed but i really didn't find any problem with it in my tried distros list.
Have you tried Fedora Eclipse or NetBeans 6.1?
Vamsi Subhash
