Old 20-12-2008, 07:46 PM   #1 (permalink)
bharat_r's Avatar
Exclamation Help needed in making an object move along a curve in VB 6
Hello
I'm trying to make this in VB 6. I have a pic of a satellite and pic of the earth. I want to make the satellite move along the curvature of the earth.
I tried changing the top & left properties of the image to make it move and tried using the do while loop to do this but am not sure how to implement it properly.
I'm attaching the .frm file.
Thank you
File Type: zip satellite 2.zip (766 Bytes, 5 views)
bharat_r is offline
Old 20-12-2008, 07:51 PM   #2 (permalink)
Section Moderator
gopi_vbboy's Avatar
Default Re: Help needed in making an object move along a curve in VB 6
Are u talking abt 2D or 3D
For 2D vb does the job
for 3d u may require dirextx or opengl or activex
gopi_vbboy is online now
Old 20-12-2008, 08:22 PM   #3 (permalink)
bharat_r's Avatar
It's 2D. I just want it to be simple schematic of how a satellite moves around the earth. After I achieve this, I also plan to move the antenna along the motion of the satellite so that it looks like the antenna is tracking the satellite.
bharat_r is offline
Old 21-12-2008, 01:26 PM   #4 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
I'd do it in photoshop and use the gif file in vb... cant you do that?
dheeraj_kumar is offline
Old 06-01-2009, 12:20 AM   #5 (permalink)
pls provide full file with project file (.vbp) also not only form file also provide pictures. I can help u frnd.
abhijangda is offline
Cowon announces new S9 Curve with looks that could kill! krazzy Technology News 15 26-08-2008 05:42 PM
(Making a school website)Help Needed? Bhuvanmittal420 QnA (read only) 5 07-05-2007 05:03 PM
Help needed in making a pc in the range of 35-36k shikhar_kapoor143 Hardware Q&A 6 19-05-2006 10:57 AM
Urgent help needed.. wanna move prog files... kuch_kehna_hai QnA (read only) 3 03-11-2005 05:17 PM
- by gforz
- by soumya
