Old 16-12-2008, 01:02 PM   #1 (permalink)
Pragadheesh's Avatar
Unhappy problem with ms access connectivity in c#
hi,
i developed a window application(a aregistration form) and tried to store the details in a database. i used ms access. here is the method for the "submit" button that would store the details in the database. my database name is Registration and table name is Registration
private void btnRegister_Click(object sender, EventArgs e)
string strConnection =
"Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\\NewReg\\Registration.mdb";
OleDbConnection con = new OleDbConnection(strConnection);
string strQuery =
"select * from Registration";
OleDbCommand aCommand1 = new OleDbCommand(strQuery, con);
OleDbDataAdapter adp = new OleDbDataAdapter(aCommand1);
con.Open();
adp.SelectCommand = aCommand1;
DataSet ds = new DataSet();
adp.Fill(ds, "Registration");
DataRow drow = ds.Tables[0].NewRow();
drow[0] = txtName.Text;
drow[1] = int.Parse(txtAge.Text);
drow[2] = txtGender.Text;
drow[3] = txtPassword.Text;
drow[4] = int.Parse(txtContact.Text);
drow[5] = txtMail.Text;
ds.Tables[0].Rows.Add(drow);
OleDbCommandBuilder builder = new OleDbCommandBuilder(adp);
adp.UpdateCommand = builder.GetUpdateCommand();
adp.Update(ds);
con.Close();
but i get exceptions stating "syntax insert into exception". why such an exception? help plz.
also i'm not much familiar with MS connectivity using C#. any sites or links from which i can learn more about it..
Pragadheesh is offline
Old 17-12-2008, 06:47 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: problem with ms access connectivity in c#
http://www.google.com/search?num=100...23&btnG=Search
http://www.google.com/search?client=...utf-8&oe=utf-8
Please search before posting.
dheeraj_kumar is offline
Connectivity problem (Rapidshare) amer Software Q&A 3 16-04-2008 06:08 AM
Connectivity problem maddy_in65 QnA (read only) 6 03-04-2008 09:48 PM
Problem with PC Suite connectivity.. kumars Software Q&A 3 10-11-2006 12:21 PM
SQL VB6 connectivity Data access error CyCo Software Q&A 1 06-10-2006 11:03 AM
pls help. connectivity problem anandk QnA (read only) 3 06-06-2005 09:58 PM
- by gforz
- by soumya
