Old 12-12-2008, 05:11 PM   #1 (permalink)
learnhardy
Default pattern problem in c
I want only program logic for this pattern ....."a c letter pyramid in which first row have one c letter ,second row have three ,third row have 5 and so on.......
please don't assign me a several printf() and tab and newline character.....as an option......!!!!
It be made with two for loops that is in one loop tab is decreasing and letter "c" is increasing in the second loops.??......or any other best option guys.....!!!!!
Newbie......
celebrate an ancient art .....
http://ambika.99k.org
Last edited by ambika; 12-12-2008 at 05:38 PM. Reason: pattern not appeared correctly
ambika is offline
Old 12-12-2008, 05:56 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: pattern problem in c
This is fairly simple, although newbies have a tough time with this. You can do it as long as you understand how the no. of letters are generated.
for row 1, 1 letter
for row 2, 3 letters
for row 3, 5 letters
for row 4, 7 letters
you can identify a simple pattern. For row number 'n', it will contain '(2*n) - 1' letters.
for( i = 1; i <= n; i++ )
    printf( "\n" );
    for( j = 1; j <= ( (2*n) - 1 ); j++)
        printf( "c" );
dheeraj_kumar is offline
Old 13-12-2008, 07:21 PM   #3 (permalink)
learnhardy
This is not the case .........this triangle is equilateral triangle.....not a right angle triangle ......!!!!
I am new to this forum can anyone assign me ....how can i use drawing tools in this forum......my pattern not appearing right.
Newbie......
ambika is offline
Old 13-12-2008, 07:54 PM   #4 (permalink)
Always confused
vamsi360's Avatar
then use nested for loops one for dividing the screen into two and starting from the middle and the other to print the letter
here it goes......very difficult to type here
main()
int i,j,n;
printf("Enter the number of lines");
scanf("%d",&n);
for(i=1,i<=n;i++)
for(j=1;j<=n-i;j++)
printf(" ");
for(j=1;j<=i;j++)
print("%4c",c);
printf("\n");
printf("\n");
Vamsi Subhash
visit my blog at www.vamsisubhash.co.cc and taste a bit of IT!
vamsi360 is offline
Old 13-12-2008, 08:05 PM   #5 (permalink)
learnhardy
Hey ,vamsi360.... u r rignt .....i am just wanted this answer from someone ...please tell me how can this be done.
Newbie......
ambika is offline
Old 13-12-2008, 08:06 PM   #6 (permalink)
Always confused
vamsi360's Avatar
starting from the first.....in the second printf the gap between the quotes is 4 spaces and hence %4d in the 3rd printf.In the thread the spaces are gone
first as I said divide the screen to half so that you can start from the middle.Hence characters get displayed on both left and right.Rest you can easily understand if you get the main logic
Vamsi Subhash
vamsi360 is offline
Old 13-12-2008, 08:19 PM   #7 (permalink)
learnhardy
can anyone provide me a online c compiler....
Newbie......
ambika is offline
Old 13-12-2008, 08:24 PM   #8 (permalink)
Commander in Chief
QwertyManiac's Avatar
Why don't you figure out a way to print spaces if this following one is what you want:
In C:
PHP Code:
#include <stdio.h>
int main(int argcchar **argv) {
int n 5ij;
printf("Enter no. of rows: ");
scanf("%d", &n);
    for(
i=1i<ni++) {
        for(
j=0j<n-i+1j++) { printf(" "); }
        for(
j=0j<(2*i)-1j++) { printf("c"); }
printf("\n");
    for(
i=ni>0i--) {
        for(
j=n-i+1j>0j--) { printf(" "); }
        for(
j=(2*i)-1j>0j--) { printf("c"); }
printf("\n");
    return
0;
There are no online C "compilers", but a useful, limited interpreter might be found here.
Output of vamsi360's program:
       c
      c   c
     c   c   c
    c   c   c   c
   c   c   c   c   c
Harsh J
www.harshj.com
QwertyManiac is offline
Old 13-12-2008, 08:31 PM   #9 (permalink)
Always confused
vamsi360's Avatar
hey qwerty i have said to adjust the spaces in quotes as I typed here and not pasted it from editor.Look at it with 4 spaces in quotes and %4c you will get the desired output
Vamsi Subhash
vamsi360 is offline
Old 13-12-2008, 08:35 PM   #10 (permalink)
Commander in Chief
I posted the output only cause I guessed the OP was looking to run it.
Harsh J
www.harshj.com
Old 13-12-2008, 08:42 PM   #11 (permalink)
Always confused
vamsi360's Avatar
ok........output is correct(I compiled in 'ancient tc' )
Vamsi Subhash
vamsi360 is offline
Old 13-12-2008, 09:06 PM   #12 (permalink)
learnhardy
Wink Re: pattern problem in c
Qwerty!!! ur code works fine ........i got my answer thanks.
Newbie......
ambika is offline
Old 13-12-2008, 09:14 PM   #13 (permalink)
Commander in Chief
Use [code][/code] tags to post any format as accurately as possible. (The problem you said earlier, about making the forum post accept your spaces.)
Harsh J
www.harshj.com
Old 14-12-2008, 10:38 AM   #14 (permalink)
Always confused
vamsi360's Avatar
Smile Re: pattern problem in c
I have been using the quick reply board most fo the times and haven't seen that. Thankyou for that. For you it shows PHP code. FIrst I thought all the answers you posted in remaining threads are in PHP. I think there is a confusion there. Use code only.
Vamsi Subhash
vamsi360 is offline
Old 14-12-2008, 11:04 AM   #15 (permalink)
Commander in Chief
Heh, I use it for syntax highlighting. They haven't installed any other language plug-ins.
Harsh J
www.harshj.com
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
JAVA Pattern ??? vineetrocks2005 QnA (read only) 3 27-04-2007 03:45 PM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Time taken to download Virus pattern file using live update agnels Software Q&A 1 11-02-2006 07:47 AM
Grid pattern (photoshop tutorial) goobimama Tutorials 1 24-05-2005 11:43 AM
- by gforz
- by soumya
