Old 11-12-2008, 03:39 PM   #1 (permalink)
Call me Sumit
esumitkumar's Avatar
Default How to practise SQL ??
Hi
I have win XP installed on my laptop. My frnd wants to learn SQL . I can teach him . But prob is that which software to install to access SQL on laptop ????
For teaching him unix , I had installed Linux and he practised on Terminal
Now how to install oracle DB and access SQL ??
Any free tool ?
Please reply and thanks
esumitkumar is offline
Old 11-12-2008, 06:08 PM   #2 (permalink)
God of Mistakes...
Garbage's Avatar
Default Re: How to practise SQL ??
Try MySQL
It's FREE and widely used (as Oracle).
And mostly, SQL queries remains same across various databases. So, don't worry.
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 11-12-2008, 06:17 PM   #3 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Use oracle and sql developer. You can also go for mysql as garbage said. Both are widely used, and are quite similar.
dheeraj_kumar is offline
Old 11-12-2008, 06:34 PM   #4 (permalink)
a_k_s_h_a_y's Avatar
download oracle or mysql.
that's with it.
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
a_k_s_h_a_y is offline
Old 11-12-2008, 06:36 PM   #5 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
If you are going to use MySQL, then also download the MySQL GUI tools. It includes a server administrator and query browser. Many people don't consider efficiency of queries and as a result, they become 'expert' in writing bloated queries and slowing the applications!
Besides, it will always leave a good impression of you if a senior sees a well-optimised query.
गीक होना माँगता
victor_rambo is offline
Old 12-12-2008, 09:08 AM   #6 (permalink)
Call me Sumit
^^ Thanks buddies ...let me try MySQL and post the results
Old 12-12-2008, 02:16 PM   #7 (permalink)
^^hey but MySql doesn't support nested queries and some other things like procedures etc AFAIK
Faun is offline
Old 12-12-2008, 02:30 PM   #8 (permalink)
Call me Sumit
arre yaar utni door koi nahin jaa raha
Old 12-12-2008, 02:49 PM   #9 (permalink)
Canon 1000D
astroutkarsh's Avatar
You can also try for SQL Server 2005 Express Edition or SQL Server 2000 Developer Edition.
Canon 1000D + 18-55 + 50mm f/1.8 + 55-250 IS :-)
astroutkarsh is offline
Old 12-12-2008, 05:14 PM   #10 (permalink)
Yes let me add.
Oracle and MySQL from SUN will completely slow down the system.
Especially Orace !!! The sql servers and other process running in the back ground eat system resources.
Old 12-12-2008, 05:36 PM   #11 (permalink)
Call me Sumit
^^^ grrrrr ye sab pehle kyun nahin bataya..
I just want a simple SQL prompt where I can create tables, run some joins , WHERE clause queries thats IT
Old 12-12-2008, 05:51 PM   #12 (permalink)
हॉर्न ओके प्लीज़
You mean subqueries or joins? It does support!
Stored procedures are supported from v5 onwards!
Originally Posted by a_k_s_h_a_y View Post
Yes let me add.
RUBBISH.
गीक होना माँगता
Last edited by victor_rambo; 12-12-2008 at 05:53 PM. Reason: Automerged Doublepost
Old 12-12-2008, 05:57 PM   #13 (permalink)
^^ Use Oracle and SQL Developer, just make sure you run it in a virtual machine.
Old 12-12-2008, 06:20 PM   #14 (permalink)
true.
Faun is offline
Old 12-12-2008, 06:33 PM   #15 (permalink)
RUBBISH.
Oh ya ? why not download and install Oracle Enterprise 10g on your system and try out !
200 MB RAM for Oralce, 20 MB for Java and few other process taking some 100 MB of RAM is not bad .. then fine !! These process load at start up ! form start your RAM is taken.
Old 12-12-2008, 06:35 PM   #16 (permalink)
better get whole package xampp, run when you need and do not waste your memory all the time
http://www.apachefriends.org/en/xampp-linux.html
Faun is offline
Old 12-12-2008, 06:42 PM   #17 (permalink)
हॉर्न ओके प्लीज़
Don't start jumping on reading my replies. I have never directed my reply towards Oracle, but towards MySQL.
गीक होना माँगता
Old 12-12-2008, 07:37 PM   #18 (permalink)
yes i don't know about MySQL !
We should install the Complete MySQL RDBMS Package and test out.
Old 12-12-2008, 08:44 PM   #19 (permalink)
Google Bot
Pathik's Avatar
+1 for XAMPP.
Pathik is offline
Want Java practise programs.... redhat Programming 2 03-04-2008 03:10 PM
- by gforz
- by soumya
