Old 09-12-2008, 10:49 PM   #1 (permalink)
Default VB 6 :Datacontrol >Delete
i am just newbee in VB
>i cr8ed a project with Data control linked to MS access
>Everything is working fine but the delete Button
it giving me error if last record is deleted
> So i need 2 prevent the deletion of last access data
How i coded =
1)
Private Sub Command4_Click()
Data1.Recordset.Delete
End Sub
2)
If Data1.Recordset.RecordCount >= 1 Then
Data1.Refresh
End If
End Sub
3)
data1.recordset.delete
if not data1.recordset.bof then
data1.recordset.moveprevious
elseif not data1.recordset.eof then
data1.recordset.movenext
else
msgbox"last Record"
end if
end sub
All these methods not working
Can any 1 pls tell me how to solve this problem .if possible with sample code
thanku vm
Rajesh345 is offline
Old 10-12-2008, 12:07 AM   #2 (permalink)
Default Re: VB 6 :Datacontrol >Delete
every thing runs fine friend nothing but what do you mean by deletion of last access data
abhijangda is offline
Old 11-12-2008, 08:01 AM   #3 (permalink)
ty abhijangda in trying 2 help me . I got the solution from another website
How 2 code it
On Error GoTo Delete_Error
If MsgBox("Are you sure you want to delete this record?", _
vbQuestion + vbYesNo + vbDefaultButton2, _
"Confirm") = vbNo Then
Exit Sub
End If
'delete the current record
datAuthors.Recordset.Delete
'move to a valid record
cmdMoveNext_Click
Exit Sub
Delete_Error:
' This error will occur if you attempt to delete an author that is related to
' another table in the biblio.mdb database ...
MsgBox "This record cannot be deleted. Error code = " _
& Err.Number & vbCrLf & Err.Description, _
vbCritical, "Cannot Delete"
link of that site
http://www.vb6.us/tutorials/database-access-vb6-data-control-tutorial
Thank u
how to delete fun.exe ?? vivekrules Software Q&A 10 05-02-2008 02:27 PM
How to delete everything kumarn_2004 Software Q&A 8 04-01-2007 08:01 PM
Cannot delete..help!!! linardni QnA (read only) 11 29-06-2006 12:32 PM
- by gforz
- by soumya
