Old 07-12-2008, 04:28 PM   #1 (permalink)
Question Urgent : Can any1 solve my problem?
Hi All,
This is the content of the file say 'input.txt'
apple   (
   ball  (
cat (
doctor(),
elephant()
cup (
dead()
As you can see its in a very haphazard manner, which is a big problem, but if you indent it properly it looks something like this
apple(
    ball(
        cat (
            doctor(),
            elephant()
        cup (
            dead()
Now what i reqire is the tree path for the last element example say for 'doctor' the tree-path is
apple.ball.cat.doctor()
and that of 'elephant' is
apple.ball.cat.elephant()
and that of 'dead' is
apple.ball.cup.dead()
';' indicates end of the path
can any automate this using any programming lang its very urgent
Thanks
srbharadwaj is offline
Old 08-12-2008, 01:30 AM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: Urgent : Can any1 solve my problem?
Do all the files have only one name(...); structure?
I've not spent much time covering up all extra conditions but for the example you have given, which has only one of those structures, this following code in Python prints it properly to an outfile.
import sys
ofile = open(sys.argv[1]+"out", 'w')
def search(tree, path='', pathlen=0):
    for each in tree:
        path += each+"."
        if tree[each]:
            search(tree[each], path)
        else:
            ofile.write(path[:-1]+'()'+'\n')
        path = path[:path[:-1].rfind('.')+1]
ip = open(sys.argv[1]).read().replace(' ','').replace('\n','')
stack = []
level = 0
result = {}
x = ip[:ip.find('(')]
ip = ip[ip.find('(')+1:-2]
result[x] = {}
ref = result[x]
for index, each in enumerate(ip):
    if each == '(':
        element = "".join(stack)
        stack = []
        ref[element] = {}
        if ip[index+1] != ')':
            skip = True
            save = ref
            ref = ref[element]
        continue
    if each == ')':
        if not skip:
            ref = save
        skip = False
        continue
    if each == ',':
        continue
    stack.append(each)
search(result)
Output:
harsh@home-desktop:~$ python3.0 a.py file.txt
harsh@home-desktop:~$ cat file.txtout
Code is partially hackish, but I'll fix that when I get free again. But for single structures its bound to work perfectly.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 08-12-2008, 12:49 PM   #3 (permalink)
yes every file will have just one name(); structure
thank a lot harsh....
Harsh, can u pls brief me abt the logic used to find out the last element?
Old 08-12-2008, 09:00 PM   #4 (permalink)
Commander in Chief
I just checked if the next element after '(', in the space-and-newline stripped file, is a ')'. If that became true, I did not add a new node to the tree and preserved the pointer (references actually, in Python).
Simply speaking, my program sees your file like this "apple(ball(cat(doctor(),elephant()),cup(dead())));" and I looked for '()'. Hackish, ugh. But did your job so its cool. I'm lazy.
By the way, why not use XML to store such data? Life could be so much easier following standards!
Harsh J
www.harshj.com
Last edited by QwertyManiac; 09-12-2008 at 12:27 AM. Reason: Automerged Doublepost
Pls..Solve my problem!!! Zangetsu Hardware Q&A 17 07-07-2008 03:21 PM
urgent help required.please solve this program. quan chi Programming 5 30-12-2007 11:45 AM
Frustating problem help needed.....any1 there..... fun_theorem Software Q&A 2 28-07-2007 05:14 PM
help to solve my DVD problem reddragon Hardware Q&A 3 20-11-2006 10:53 AM
Urgent Help Needed 2 Solve Win Xp Problem SLIPKNOT Software Q&A 7 17-11-2006 12:22 PM
- by gforz
- by soumya
