Old 03-12-2008, 11:42 PM   #1 (permalink)
Exclamation images not displayed when running page through local server
Hello this is Dhiraj!!
I've been making this project in JSP+HTML and I am facing this problem...
When I try to run an HTML file from my local server the images of the page do not get displayed properly. Everytime few of the images are shown missing.
But when I try and simply run the HTML file without the server then the images are properly displaying....what could be the problem?
I am using Tomcat Apache server and have been trying to run pages in both Firefox and IE.
Can somebody help me with that.
dhiraj_ is offline
Old 03-12-2008, 11:44 PM   #2 (permalink)
Default Re: images not displayed when running page through local server
relative URLs maybe? very probable I think.
Make them absolute.
tech_payne is offline
Old 04-12-2008, 12:08 AM   #3 (permalink)
relative URLs should be fine. Post your directory structure.
Bandu is offline
Old 04-12-2008, 12:39 AM   #4 (permalink)
..as all the images for a page are in separate images folder.
The directory structure is
jakarta-tomcat-5.5.9/webapps/ROOT/Dhiraj/images/header1_r2_c4.gif
Why there is difference...the exact problem is some of the images from that folder are displayed and some are not.
dhiraj_ is offline
Old 04-12-2008, 12:46 AM   #5 (permalink)
As you said earlier that some are displayed and some are not, I guess it must be the case that the images are displayed on a certain page of your application and not displayed entirely on some other page. Might be because the later one is in a different directory structure.
To refer the image from a html / jsp, say in ROOT/Dhiraj you will have to write
<img src='images/header1_r2_c4.gif'/>
But, if the file using the image is in say, ROOT/someotherfolder, then it would be:
<img src='../images/header1_r2_c4.gif'/>
Do let me know if we are on the same lines. If possible, paste some snippets of conditions where the images don't work.
Bandu is offline
HELP setting up Local Web Server sridatta QnA (read only) 6 12-02-2007 10:52 PM
I CANT SURF THE NET ( PAGE CANNOT BE DISPLAYED)........ dinesh_mettur QnA (read only) 10 24-02-2006 12:13 AM
Images not displayed sometimes in Firefox bharat_r Internet & WWW 7 28-07-2005 05:08 PM
Page can't be displayed techpro_bunty QnA (read only) 3 14-01-2005 04:52 AM
- by gforz
- by soumya
