Old 02-12-2008, 12:10 AM   #1 (permalink)
Rubik's Uncle!!
Charan's Avatar
Red face Web Designing/programming help
hey guys, I was basically a windows developer till now, but now I have been assigned 3 website development work. I have to build the sites from scratch. I am perty ok with Photoshop to create web the webpage layouts and then slice the PSD and open up in Dreamweaver, but here is where it ends, I cannot figureout the correct way of doing it i.e., exporting from PS to DW properly. Can you guys point me to any sources which would help me out on this.
Charan is offline
Old 02-12-2008, 12:16 AM   #2 (permalink)
Default Re: Web Designing/programming help
Well...you have to learn CSS throughly then :/ Gigacore can help here
And AFAIS, don't use too much images. Make it minimal and separate HTML(content) from CSS well.
Perfect example I can give is Drupal's default theme, it's elegant:
Faun is offline
Old 02-12-2008, 12:21 AM   #3 (permalink)
Alive Again...
satyamy's Avatar
see u can learn HTML & CSS from webdevelopersnotes.com & w3schools.com
but it will take time for u to learn than make all the 3 sites
! जय हिंद ! Proud to be INDIAN
satyamy is offline
Old 02-12-2008, 01:23 AM   #4 (permalink)
Rubik's Uncle!!
Charan's Avatar
Thanks for the reply guys, I should have learnt web designing atleast a year ago but didnt have time . looks like I have to burn more midnight oil .
BTW is it better to use CMS instead of creating sites from scratch?? joomla and drupal looks interesting but dono if it will suite my sites!!
Charan is offline
Old 02-12-2008, 01:28 AM   #5 (permalink)
Commander in Chief
QwertyManiac's Avatar
'Content management', if that's required, do use Drupal/Joomla/etc. Else you can do it in your own way!
Harsh J
www.harshj.com
QwertyManiac is offline
Old 02-12-2008, 01:40 AM   #6 (permalink)
Drupal, it's good and strict standard compliant. A nice theming engine too.
Faun is offline
Old 02-12-2008, 09:50 AM   #7 (permalink)
Elevating Humanity
The Conqueror's Avatar
Yeah using CMS will be less time consuming.I Recommend to use Joomla because -
1.Security
2.Millions of themes available
3.Very easy to use and install
4.Thousands of components can be added ,for eg guestbook, google analytics,etc
Regards,
The Conqueror
The Conqueror is offline
Old 02-12-2008, 10:24 AM   #8 (permalink)
Alive Again...
satyamy's Avatar
ya me too prefer & uses Joomla
satyamy is offline
Web Designing!! digster QnA (read only) 14 21-07-2008 11:52 PM
Unix(shell Programming) and TCP/IP programming tutorials Matrix Programming 4 08-04-2008 09:54 PM
Web Designing nareshwithu QnA (read only) 6 30-06-2007 09:39 AM
Web Designing shashank_digitreader Tutorials 5 06-10-2006 01:08 AM
Web Designing ravishankar QnA (read only) 11 20-01-2005 11:34 PM
- by gforz
- by soumya
