Old 01-12-2008, 03:02 AM   #1 (permalink)
Default Visual Basic 6 :Problem with mdb while installing
[IMG][/IMG]
i created a Standard exp with Data control
Properties of data control
Database name : C:\Program Files\mythwar calc\mythwar 2 skills.mdb
Features of my program : can save some values in specific Text box to mdb(access)
Problem i am facing
I created package using PDWizard then given to my other user who need program
but he is telling that error is comming showing mdb file is missing
Problem was solved after coping mdf file to his C:\Program Files\mythwar calc\mythwar 2 skills.mdb
this is becoming annoying , can any 1 tell me how to solve this ?
that is when every time user install program to specific location my Program should automatically relink the mdf to that specific folder where he chosed to install my program
so mdb file missing error will not come
pic of similar error when i try to replicate the error
Rajesh345 is offline
Old 01-12-2008, 10:08 AM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: Visual Basic 6 :Problem with mdb while installing
Put the database in your development root (To get a relative path). This way it'll get packaged and installed along just fine. No path issues.
Harsh J
www.harshj.com
QwertyManiac is offline
Visual Basic help! romeo_8693 QnA (read only) 18 17-02-2007 07:55 PM
visual basic small but big problem amandeep2707 QnA (read only) 3 22-01-2007 11:48 AM
Visual Basic....! vineetrocks2005 QnA (read only) 2 20-06-2006 11:25 PM
Visual Basic 6 installation problem iNFiNiTE Software Q&A 2 07-11-2005 09:09 AM
Visual Basic 6.0 godsownman QnA (read only) 5 18-04-2005 06:27 AM
- by gforz
- by soumya
