Old 18-11-2008, 01:42 PM   #1 (permalink)
sachin_kothari's Avatar
Question SQL Query Error
$sql=mysql_query("INSERT INTO `survey_result` (`Name`, `Email`, `AgeGroup`, `NetAccess`, `DayOnline`, `WeekOnline`, `Activities`, `NewsRead`, `NewsSection`, `ClickAds`, `AdInfo`, `LikeIdea`, `Suggestion`) VALUES
($name, $email, $age_group, $net_access1, $day_online, $week_online, $activities1, $news_read, $news_section1, $click_ads, $ad_info1, $like_idea, $suggest)") or die(mysql_error());
What's wrong with this query? Its giving me an error saying that "error in SQL Synatax". Please help me.
sachin_kothari is offline
Old 18-11-2008, 04:29 PM   #2 (permalink)
Default Re: SQL Query Error
try this
insert into survey_result values('&name','&email','&agegroup','&netaccess',' &dayonline','&weekonline','&activities','&newsread ','&newssection','&clickads','&adinfo','&likeidea'
,'&suggest');
techtricks.co.in
portforwarding
xp-vista crossover connection
installing xp on vista notebooks
sreenidhi88 is offline
Old 18-11-2008, 05:10 PM   #3 (permalink)
Thanks for your reply dude. But this does not seems to be working. It insert &name, &email and so in my database, not their actual values. My mysql version is 5.0.67
Old 18-11-2008, 05:25 PM   #4 (permalink)
The Linux Man !
paragkalra's Avatar
Try inserting data manually through GUI like PHPMyAdmin or SQLYOG. It will generate the sql query which you can compare with yours.
Parag.A.Kalra, The Linux Man
http://www.paragkalra.com/
In this world without WALLS and GATES who need WINDOWS! USE LINUX! STOP PIRACY! GO OPEN SOURCE!
paragkalra is offline
Old 18-11-2008, 06:07 PM   #5 (permalink)
Recosrds are getting inserted by doing it manually. But it isnt working through the code. I tried getting the values from my form to the database page. I am getting all the values alright. Its just that the query is not executing.
Edit: I tried generating the PHP code as you said and i got this
$sql = 'INSERT INTO `survey_result`(`Name`, `Email`, `AgeGroup`, `NetAccess`, `DaysOnline`, `WeeksOnline`, `Activities`, `NewsRead`, `NewsSection`, `ClickAds`, `AdInfo`, `LikeIdea`, `Suggestion`) VALUES ('
. ' \'Sachin Kothari\', \'sachin@sachin.com\', \'22-35 years\', \'/Home/Office/NetCafe/Othe\', \'More than 6 hours\', \'Daily\', \'/E-Mail/Search/Entertainment/Chat/Online Shopping/Social Networking/News/Work/Test\', \'Yes\', \'/Frontpage/Business/Sports\', \'Only if it is related to my needs\', \'/NewsPapers/Friends/Test\', \'Excellent Idea\', \'Test\')';
What are the slashes doing here? How do i modify it to make it work with the query?
Its working. I used this query.
$query = "INSERT INTO `survey_result` (`Name`, `Email`, `AgeGroup`, `NetAccess`, `DaysOnline`, `WeeksOnline`, `Activities`, `NewsRead`, `NewsSection`, `ClickAds`, `AdInfo`, `LikeIdea`, `Suggestion`) VALUES
('$name', '$email', '$age_group', '$net_access1', '$day_online', '$week_online', '$activities1', '$news_read', '$news_section1', '$click_ads', '$ad_info1', '$like_idea', '$suggest')";
Last edited by sachin_kothari; 18-11-2008 at 06:24 PM. Reason: Automerged Doublepost
Old 18-11-2008, 07:10 PM   #6 (permalink)
Commander in Chief
QwertyManiac's Avatar
Escaping (The slashes do that)
Harsh J
www.harshj.com
QwertyManiac is offline
Old 18-11-2008, 07:24 PM   #7 (permalink)
spice it up
kapsicum's Avatar
do this ...
PHP Code:
$sqlmysql_query("INSERT INTO `survey_result` (`Name`, `Email`, `AgeGroup`, `NetAccess`, `DayOnline`, `WeekOnline`, `Activities`, `NewsRead`, `NewsSection`, `ClickAds`, `AdInfo`, `LikeIdea`, `Suggestion`) VALUES (".$name.", ".$email.", ".$age_group.", ".$net_access1.", ".$day_online.", ".$week_online.", ".$activities1.", ".$news_read.", ".$news_section1.", ".$click_ads.", ".$ad_info1.", ".$like_idea.", ".$suggest.")") or die(mysql_error());
let me know if ur problem is solved
kapsicum is offline
Old 18-11-2008, 09:46 PM   #8 (permalink)
toofan's Avatar
you just break the code in two segments then everything would be ok. do as follows.
Copy this code and past it.
$query = "Insert into survery_result (Name, Email, AgeGroup, NetAccess, DayOnline, WeekOnline, Activities, NewsRead, NewsSection, ClickAds, AdInfo, LikeIdea, Suggestion) VALUES
$result = mysql_query($query);
Don't use ' ' sings in the table name and the fild names.
Check my work at:
http://www.flickr.com/photos/vimaljoshi
toofan is offline
Old 18-11-2008, 09:55 PM   #9 (permalink)
Commander in Chief
Er guys, he already has solved it an hour earlier than kapsicum's post
Harsh J
www.harshj.com
Old 19-11-2008, 09:27 AM   #10 (permalink)
yup guys, its solved.
anyway thanks for all your responses.
Splinter Cell:Double Agent Visual C++ runtime error and ***MUST CHECK*** error zerohourkill Gamerz 17 04-08-2007 02:47 PM
Post Vista installation query!!! "CPU OVERVOLTAGE ERROR"!!! sude CPU / Motherboards 1 18-02-2007 08:53 PM
Windows XP Booting and Installation Error (LILO Error) arijitraja Software Q&A 3 26-02-2006 03:32 PM
Microtek Monitor Query and PHPBB Attachment Mod Query vwad Software Q&A 1 20-03-2005 09:32 AM
Error error error....gives me hell of a terror abhilash QnA (read only) 4 06-11-2004 12:41 AM
- by gforz
- by soumya
