Old 16-11-2008, 07:35 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
sganesh's Avatar
Default Need Help in creating online quiz application using JSP
Hi,
i am creating online Quiz application using JSP and MySQl ,Apache 6 in Netbeans IDE.
i am able to successfully display first question from database,and can say the answer is correct or not,,but i can't implement the program further ,in such way that when clicking next button ,new question gets displayed and score calculated there after!,
index.jsp
Document : start
Created on : Nov 16, 2008, 2:58:18 PM
Author : Ganesh
<%@ page import="java.sql.*" %>
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
"http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<title>JSP Page</title>
</head>
<body>
<% String ans=" ";
Connection conn = null;
Statement st = null;
ResultSet rs = null;
int i=1;
String s,g;
int count=0;
try {
//Class.forName("com.mysql.jdbc.Driver").newInstance ();
conn =
DriverManager.getConnection("jdbc:mysql://localhost:3306/MyNewDatabase","root","");
st = conn.createStatement();
//for(i=1;i<=2;i++)
rs = st.executeQuery("select * from quiz where n="+i);
while(rs.next()) {
<form name="form1">
Question:
<h3> <%= rs.getString("quest")%></h3>
1: <%= rs.getString("a") %> <input type="radio" name="a" value= "a" />
2: <%= rs.getString("b") %> <input type="radio" name="a" value="b" />
3:<%= rs.getString("c") %> <input type="radio" name="a" value="c" />
4: <%= rs.getString("d") %> <input type="radio" name="a" value="d" />
<input type="submit" value="OK">
</form>
<% g=request.getParameter("a");
<% ans= rs.getString("ans");
if(g.equals(ans)){
count++;
out.println("Correct");}
else
out.println("false");
catch (Exception ex) {
ex.printStackTrace();
} finally {
if (rs != null) rs.close();
if (st != null) st.close();
if (conn != null) conn.close();
out.println("Score="+count);
</html>
contents of database
mySql-->select * from quiz;
quest a b c d e ans
What is capital of india Chennai Mumbai Delhi bangalore c 1
What is capital of tamil nadu Chennai madurai trichy coim a 2
i need Some ideas to build this project !!!
sganesh is offline
Old 16-11-2008, 11:25 PM   #2 (permalink)
Default Re: Need Help in creating online quiz application using JSP
what you are doing is not a best practice you should write business logic in java
try Struts 2 it is quite easy to learn and very effective in developing any kind of application in very short time.
Dhiraj Thakur
thakur.dheeraj(@)gmail.com
Desi-Tek.com is offline
Old 17-11-2008, 09:53 AM   #3 (permalink)
CAFEBABE
chandru.in's Avatar
@sganesh
What Desi-Tek told is right. What you are doing is completely bad way of doing it and IMHO it is a reason you are stuck. Even if you don't want to use any framework, I'd suggest you to read up on MVC architecture. It will make your life a breeze once you learn.
A simple MVC for your case would be writing a servlet, which invokes quiz validation code from another simple class. All JSPs can post to this servlet and the servlet should dispatch to appropriate JSP after validation.
I personally like not using frameworks for simple apps and for complex apps I prefer JSF.
Chandru
http://tuxychandru.blogspot.com
chandru.in is offline
Old 17-11-2008, 11:57 AM   #4 (permalink)
sganesh's Avatar
ok fien,i thought to reimplement the project in Struts,
Thanks!
sganesh is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/programming/102235-need-help-creating-online-quiz-application-using-jsp.html
in creating online quiz application using JSP Programming Question This thread Refback 23-06-2010 02:41 PM
Errors !!! -> A rant about online application errors Bandu Chit-Chat 5 22-08-2008 11:15 PM
IT quiz maharajadhiraj QnA (read only) 1 19-10-2005 07:59 PM
Please Help ! A big Quiz really! huzaifa b arab QnA (read only) 12 18-05-2005 03:53 AM
- by gforz
- by soumya
