Old 13-11-2008, 08:56 PM   #1 (permalink)
Default simple usb cleaner
guys i have developed my first .net application.its called simple usb cleaner.it cleans your flash drives and other drives from unwanted files.
i just want the forum members to try it out and suggest something.
please have a look at it.
you can download it here. it requires .net framework 3.5
http://techtricks.co.in/?p=123
please suggest the features i can add to it.
techtricks.co.in
portforwarding
xp-vista crossover connection
installing xp on vista notebooks
sreenidhi88 is offline
Old 13-11-2008, 09:17 PM   #2 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
Default Re: simple usb cleaner
Can you tell us more about what we should expect after starting yhe app?
गीक होना माँगता
victor_rambo is offline
Old 13-11-2008, 09:48 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
Whoa, easy on the bling factors! A splash has guidelines on why it even exists, did you know? And so does every other UI factor, like the menus, the title-bar, etc ...
While I don't have an infected pen-drive to test this upon (Nor one with hidden/system files on it), I did try it on C:, up till the list level of course. Rest must be straightforward I guess, removing all checked files.
I'm guessing the only way you can make this app better is to somehow make it handle every USB disk auto-mount and sanitize it. That would be a fantastic tool to use, since every other person today carries infected USB drives.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 13-11-2008, 10:08 PM   #4 (permalink)
thanks for the suggestion pal.
@rohan shenoy
tell me how i can improve.you have to be more clear.i am not claiming it as a "bigshot'' app. its my first appli ,and i wud like to hear suggestions on improving.
techtricks.co.in
portforwarding
Old 13-11-2008, 10:15 PM   #5 (permalink)
हॉर्न ओके प्लीज़
oh, you misunderstood.
Actually, I am not able to understand what exactly your app will do after running it. 'Unwanted files' means what? malware files? duplicate files? anything other?
And so I asked you what should I expect it to do.
गीक होना माँगता
Old 13-11-2008, 10:36 PM   #6 (permalink)
i thought you read the blog post before downloading.anyways,it just displays list of files in your flash or any drive,and if you think you dint put them ,then it must be unwanted(virus,trojan,autorun,recycler,regsvr) ,and if you cant delete them the usual way,you can use this app to delete this.
the main reasson i developed this was,my friend had got this winthb.exe virus which changed the icon of c: drive (system drive) and messed up the system. mcafee could not permanently delete it.
i tried the usual "dos commands attrib -s -h " way and removed it successfully.now i thought average computer user would find it difficult to type in those commands in cmd , so let me give him a gui way.
and thus (very) simple usb cleaner was born.
techtricks.co.in
portforwarding
Old 13-11-2008, 11:04 PM   #7 (permalink)
हॉर्न ओके प्लीज़
hmmm....seems nice then!
गीक होना माँगता
Old 13-11-2008, 11:19 PM   #8 (permalink)
gsmsikar's Avatar
i will try this software , i need a software like this as i do get many flash drives and memory cards in my PC ..
thanks
gsmsikar is offline
Cleaner dhanusaud Mobiles and Tablets 4 17-03-2008 06:04 PM
PC-Cleaner registry cleaner to fix your errors systemcleaner QnA (read only) 6 09-03-2007 06:34 PM
Registry Cleaner pritish_kul2 QnA (read only) 10 02-10-2006 06:02 PM
CD cleaner - Rs 80 ok or not ? reddragon Hardware Q&A 5 23-08-2006 03:30 AM
After using ATF Cleaner saiaspire QnA (read only) 2 04-06-2006 05:36 PM
- by gforz
- by soumya
