Old 07-11-2008, 01:20 PM   #1 (permalink)
Manojap's Avatar
Post Pointer Magic
Find sum of 10 nos using array of size 1 and two *pointers
int x[1],i,*xptr,i,*s;
for(i=0;i<10;i++)
scanf("%d",&x[i]);
xptr=&x;
for(i=0;i<10;xptr++,i++)
*s=*s+*xptr;
prnitf("%d",*s);
manojap
Manojap is offline
Old 08-11-2008, 07:51 PM   #2 (permalink)
Default Re: Pointer Magic
I do not understand what is being done in the code! It seems flawed - use of uninitialized pointers, invalid pointer assignments, etc - care to explain?
srinivasa.s is offline
Old 18-11-2008, 06:10 AM   #3 (permalink)
Pragadheesh's Avatar
in the first line, 'i' has been declared twice and in the last line, its 'printf' and not 'prnitf'.
other than these errors the program compiles successfully, but doesn't run.
the reason is you used x as 'x[10] instead of x[1]'. i.e u tried to store all the 10 values in consecutive locations of x declaring it as an array of size 1.
declaring x[1] and referencing other indexes like x[2], x[3] etc is the reason for this error.
just type, x[10] in the first line instead of x[1]. it works perfectly. so go for a different logic.
Pragadheesh is offline
Problem with Pointer in Structure veddotcom Programming 5 01-10-2008 09:36 PM
pointer to 2-D array INS-ANI Programming 2 24-03-2008 09:31 PM
Microsoft pointer jumps g_goyal2000 Hardware Q&A 19 02-12-2007 10:34 AM
Mouse pointer behavior patkim Peripherals 3 22-06-2007 02:35 PM
Mouse pointer behaves stupidly @#$%^& kl_ravi Peripherals 1 25-01-2005 10:59 AM
- by gforz
- by soumya
