Old 01-11-2008, 07:39 PM   #1 (permalink)
gkbhat.blogspot.com
Default Problem with system() function in C
I want to run a program that has to rename a folder H:\gk1\gk1 to gk2
When I run that command using
system("move H:\gk1\gk1 gk2");
it reports an error that "Bad command or file name" .
I even tried the rename command it give "Invalid path or filename"
The specified folder exists and no other application is using it.
If I run the same command from the command prompt it executes.
Please help me..I'm struck with my prog.
blogging at http://gkbhat.blogspot.com
gk2k is offline
Old 01-11-2008, 07:46 PM   #2 (permalink)
swatkat's Avatar
Default Re: Problem with system() function in C
Hmmm... This worked for me:
system( "ren c:\\gk1\\gk1 gk2" );
Give two back-slashes (\\). In your code, the character "g" gets escaped...
http://swatrant.blogspot.com/
swatkat is offline
Old 02-11-2008, 07:29 AM   #3 (permalink)
gkbhat.blogspot.com
I tried that it gives error "Invalid Path or filename"
Even the cd command gives"Invalid directory"
I've attached my code here
#include<stdio.h>
#include<conio.h>
#include<stdlib.h>
int main()
system( "dir/p/a");
system( "cd gk1" );
system( "dir/p/a");
system( "rename c:\\gk1\\gk1 gk2" );
getch();
return 0;
I execute this programme in C:\ directory
gk2k is offline
Old 02-11-2008, 09:00 AM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
Shouldn't there be space between a command and its arguments?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 02-11-2008, 04:47 PM   #5 (permalink)
gkbhat.blogspot.com
Which command are you pointing to?
If it's dir/p/a it can be given without space also
gk2k is offline
Old 15-11-2008, 10:11 AM   #6 (permalink)
gkbhat.blogspot.com
Any help please?
gk2k is offline
Old 15-11-2008, 10:42 AM   #7 (permalink)
parthbarot's Avatar
i think only 2 things...
1. Must use #include <stdlib.h>
2. If command runs on DOS then must run through system command...
and it will move ( move H:\gk1\gk1 gk2 ) in the current directory... i tried...it worked...
regards.
www.techlads.com
Paarth.
parthbarot is offline
Old 15-11-2008, 03:27 PM   #8 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
You are supposed to insert the FULL address in both the source and the destination.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 17-11-2008, 03:00 PM   #9 (permalink)
parthbarot's Avatar
i dnt think so.... because it will make the new folder 'gk2' in the current folder itself...so it does't matter i think...
regards.
www.techlads.com
Paarth.
Old 17-11-2008, 03:15 PM   #10 (permalink)
The Smaller Bang
^^Exactly. But what is that your intention in the first place ?
And one more question: Doesn't the system() function accept an array of characters as an arguement and executes the statement in the array as a command in the shell ? So this is an OS dependant question which has little to do with programming error and more to do with the OS he uses.
Old 17-11-2008, 03:25 PM   #11 (permalink)
Krazy_About_Technology's Avatar
If you are running it from within the compiler IDE the system() function won't work. Compile the program and then run the exe from commandline. You can find out where the output exe is produced in the configuration dialog of your compiler. I assume you are using the same age old Turbo C++ (Yuck!) IDE so you can go to Options>Directories and look at the value of Output Directory. if nothing is there then the output executable will be created in the bin directory of your compiler installation folder.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
Krazy_About_Technology is offline
Old 20-11-2008, 07:48 AM   #12 (permalink)
gkbhat.blogspot.com
@MetalheadGautham
I just want to write a program to rename a folder taking old and new folder name as argument.I didn't get a built in c function to rename the folder.
Some commands like "dir" works.I use tc with windows xp.
@Krazy_About_Technology
I run the exe through the command line only.
gk2k is offline
help with command line problem dead_eye Software Q&A 3 29-09-2008 09:06 PM
problem with command prompt dhiraj_ Software Q&A 10 08-09-2008 11:37 PM
system command c/c++ internet.sid Programming 2 17-08-2008 09:56 PM
command prompt problem bukaida QnA (read only) 2 22-01-2006 08:26 PM
