Old 27-10-2008, 10:40 AM   #1 (permalink)
Thumbs up help in selecting programming technique
I need a simple INVENTORY program, where 50 inventory Items are listed and by its side the stock is displayed and there are two buttons "in" for adding and "out" for deducting stock.
What programming technique (Language or Methodologies) would be best?
longlife is offline
Old 27-10-2008, 10:57 AM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: help in selecting programming technique
Using VB would be the quickest way to do this. All you need is a simple 2 column table (Or even listboxes would do, DB reqd?) and 2 buttons for doing the increment and decrement tasks upon it.
You've not mentioned your target platform though.
Harsh J
www.harshj.com
QwertyManiac is offline
Unix(shell Programming) and TCP/IP programming tutorials Matrix Programming 4 08-04-2008 09:54 PM
Selecting OS... rthegr81 Software Q&A 3 27-06-2006 02:24 PM
H.264 technique for AVI rahul_becks23 Software Q&A 2 25-05-2006 06:59 PM
StreamUpload releases clustered search technique ferrarif50 Technology News 1 21-05-2006 12:26 AM
