Old 26-10-2008, 09:35 PM   #1 (permalink)
jatt's Avatar
Default Help regarding language problem on a forum
Hi friends , i created a forum on x10hosting.com,its working fine but i have a problem in punjabi language.I want to use this forum in english and punjabi both.but when i write punjabi it shows this in ??????????????? form.On the otherhand i can able to write and see in punjabi on different forums like on thinkdigit.com too,What i need to fix ,to overcome this problem.please suggest here.and yes i m using SMF forum.
ਨੋ ਗਰਲ ਫਰੈਂਡ ਨੋ ਟੈਂਨਸ਼ਨ,no girlfriend no tension,website: Punjabi.c-o.in,forum: punjabiteacher.co.cc
jatt is offline
Old 26-10-2008, 10:18 PM   #2 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
Default Re: Help regarding language problem on a forum
Probably, the meta tags are not telling the browser to use an appropriate encoding.
गीक होना माँगता
victor_rambo is offline
Old 27-10-2008, 06:30 AM   #3 (permalink)
jatt's Avatar
then what can we do now.please help.
jatt is offline
Old 27-10-2008, 01:06 PM   #4 (permalink)
हॉर्न ओके प्लीज़
oh sorry, forgot to include the solution.
In the settings section, there must be a settings that allows you to choose the encoding set. Check if that works.
गीक होना माँगता
Old 27-10-2008, 01:59 PM   #5 (permalink)
jatt's Avatar
in which type settings,do you talking about utf -8 etc or such type settings i have already do to convert utf-8 etc. but all useless.
please give some more details here.thanks
jatt is offline
Old 27-10-2008, 05:09 PM   #6 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
@jatt
When you sign up on x10, you need to confirm that the content of your site will only be in english or 2 other languages(french and something else) or if its in another language, a complete english translation will be provided.
Ask in x10 forums if its okay. Else, your site will be terminated.
dheeraj_kumar is offline
Old 27-10-2008, 05:37 PM   #7 (permalink)
jatt's Avatar
thanks and i will conform it but i think there is not such type problem its the problem in somewhere in settings only.
jatt is offline
MS-Office Language Problem - HELP !!! Please steelwin Software Q&A 1 13-03-2008 09:26 PM
Windows Vista Language Problem..Please help sanjaykanade Software Q&A 3 13-09-2007 11:13 PM
'Assembly Language Programming' Problem a_to_z123 Programming 5 03-12-2005 02:51 PM
problem in installing HINDI language pack for winXP PRO SP2. kool Networking 3 03-04-2005 02:34 AM
Language Problem In Internet Explorer 6 TheUndead Internet & WWW 5 20-08-2004 04:38 PM
