Old 24-10-2008, 11:30 AM   #1 (permalink)
You gave been GXified
gxsaurav's Avatar
Default Need help in creating a CHM Viewer
Today I download an E-Book in CHM format & something struck my mind. Although I am using a cyber cafe computer to read this CHM but I found that other then UltraCHM which is paid there is no good looking CHM Viewer for Windows, whether XP or Vista.
The default one in Windows XP & Vista is same like the one released in 1998. I wanted to make it better but don't know how to code. I am looking for help, can someone make a good looking & half decent CHM Viewer with me in .net? I will give the UI Component & how to make the deisgn, you will have to make the underlying engine & program it. The default one in Windows is good enough as far as layout etc is concerned so lets make the default one look & function better....
If you are interested, let me know. I will give the UI components as soon as I get back to Lucknow. It can be made either in WPF (prefered as the backend code is just .net) as well as WinForms(what matters here is the looks cos HTML is rendered using IE engine which isn't WPF accelerated anyway)
about.me/gxsaurav
gxsaurav is offline
Old 24-10-2008, 04:45 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: Need help in creating a CHM Viewer
^^ I was facing the same problem last month. I downloaded an ebook, and couldnt get the HTML Help to zoom in more than it did, for easy reading. I did some research on it, and here are some links:
http://www.ultrachm.com/ - UltraCHM, it has the zoom feature I needed. Paid.
http://www.help-explorer.com/downloads.php - Help Explorer Viewer - supports Help 1 & 2, Free for single-user.
http://www.helpware.net/ - Viewers for Help 1 & 2. Free. Also contains lots of info.
http://chmspec.nongnu.org/latest/index.html - CHM file format, completely documented.
dheeraj_kumar is offline
Old 25-10-2008, 01:59 PM   #3 (permalink)
gxsaurav's Avatar
^^^ i saw those apps but didn't like them much. First they don't fit in the Windows Vista's look & feel environment & 2nd, they don't have enough features & sometimes overkill. That's y I decided to make my own....
about.me/gxsaurav
gxsaurav is offline
Old 25-10-2008, 06:18 PM   #4 (permalink)
Rubik's Uncle!!
Charan's Avatar
@Gx : I will check it out.
Charan is offline
Old 13-11-2008, 04:57 PM   #5 (permalink)
gxsaurav's Avatar
Like I said previously, since I was out of Lucknow & had no computer & internet here...I am a bit late in posting the application Mock UI here. Today it is complete, here is the Photoshoped Render of what I call "Help Manual"
Now, I need help from some developers for this. I can provide the UI elements etc but someone need to program it. Charan, your help is appriciated
about.me/gxsaurav
gxsaurav is offline
Old 13-11-2008, 11:49 PM   #6 (permalink)
Rubik's Uncle!!
Charan's Avatar
upload the required UI elements to Skydrive and give me the link .
Charan is offline
Old 14-11-2008, 12:39 AM   #7 (permalink)
gxsaurav's Avatar
I am having problem with my BSNL connection. None of the Microsoft website is opening. I will give you on Yahoo Messenger.
about.me/gxsaurav
gxsaurav is offline
Old 19-11-2008, 12:18 PM   #8 (permalink)
OSS Enthusiast!
nitish_mythology's Avatar
Make it opensource
Do you know, Shinigamis only eat apples???
nitish_mythology is offline
Old 20-11-2008, 03:14 PM   #9 (permalink)
CAFEBABE
chandru.in's Avatar
Originally Posted by nitish_mythology View Post
Make it opensource
Do you know whom you are speaking to?
Chandru
http://tuxychandru.blogspot.com
chandru.in is offline
Old 29-11-2008, 01:33 AM   #10 (permalink)
OSS Enthusiast!
Who knows...he might just accept my suggestion
Old 29-11-2008, 12:38 PM   #11 (permalink)
Krazy_About_Technology's Avatar
Hey GX, there is a CHM viewer for Windows Mobile written in C#, its called CHMReader.net. Its an open source project at CodeProject.com. You can download it and source code @ http://www.codeproject.com/KB/mobile...ew=Quick&fr=26
I think the code can be easily used for a desktop app as far as parsing of CHM files is concerned. have a look at it.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
Krazy_About_Technology is offline
Old 29-11-2008, 01:58 PM   #12 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
^^Now THATS what I am talking about. I knew there was a .net app made for CHM viewing. But I forgot the name. This may or may not be the one I heard of, but its a nice place to start. Porting the code to Windows Vista should be somewhat straightforward I guess.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 29-11-2008, 10:28 PM   #13 (permalink)
gxsaurav's Avatar
The engine can be easily made yaar, it's just IE's HTML engine to decode the CHM. I m making the UI these days in WPF, weekends par hi time milta hai ab to
about.me/gxsaurav
gxsaurav is offline
Old 30-11-2008, 12:26 AM   #14 (permalink)
Well, then what is left? UI, you are designing. Engine, can be made easily as you said. The only thing that remains is the plumbing code for the UI that connects it to the engine features and there you have it. I was thinking that the Engine for the programmer and UI for the designer, will take most of the time.
I understand that CHM files are just HTML files compiled together into a single file along with extra features like the table of contents and search functionality. I will study the project and try to implement something in .NET 3.5 compatible code (the engine part). Lets see if i could make something out of it.
Event Viewer girishrn Software Q&A 1 13-03-2008 04:05 PM
how to use cache viewer PainKiller Software Q&A 12 09-10-2006 01:29 AM
image viewer of win xp amrit1 Software Q&A 5 08-06-2006 11:03 PM
PDF viewer equipment nitinjavakid Software Q&A 7 14-04-2006 02:44 PM
SIS files viewer harsh bajpai Mobiles and Tablets 5 28-10-2005 11:07 PM
