Results 1 to 24 of 24
  1. #1
    Why So Serious ??? mandarpalshikar's Avatar
    Aug 2012
    Pune
    Question Suggestions for PSU
    Hi Folks... I'm currently usingCorsair CMPSU-650TXV2UK 650 Watts PSU. My config is as follows
    Core i5 3570K (planning to overclock)
    CM Hyper 212 Evo (2 fans - push-pull config)
    Asus Maximus V Gene
    G.Skill Sniper 1600MHz 4GB x 2
    ASUS HD7950 DirectCUII (planning to overclock)
    Corsair Force 3 60GB SSD
    Seagate Baracuda 1TB HDD
    LG DVD Writer x 2
    Silverstone Raven RV03 cabinet with 2 180MM & 1 120MM fan
    Not that current PSU is giving trouble but my guess is I need to upgrade my PSU to 800 or 850 watts one if I want to try my hands at overclocking... right ? If yes then please guide me in choosing one within budget of 8K (can I get a modular PSU within this budget ?)
    Also can someone please explain the difference between Corsair GS and TX series ? TX850 is costing around 7500 and GS800 around 6800. So need to know the difference between them. Shall I consider any other manufacturer other than Corsair like Antec or FSP ? Actually FSP offers modular variant around 8.5k - FSP Aurum AU-750M
    Please suggest.
  2. #2
    Human Spambot The Sorcerer's Avatar
    May 2008
    Default Re: Suggestions for PSU
    Quote Originally Posted by mandarpalshikar View Post
    No- who told you that???
  3. #3
    Aug 2012
    Pune
    So my Corsair TX650 is perfectly fine for my requirements ? Basis on which I was thinking to upgrade was that when I overclock, components such as processor and graphics card will require more juice and TX650 will fall short to provide it.
  4. #4
    Aug 2007
    Chinchwad Pune
    650W is enough for the OC. I see no issues.
    Phenom II 955 BE | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Kingston v300 SSD 240 GB | Seagate : 1 TB | NZXT Phantom 410 | Sony Experia Neo V
  5. #5
    In search for Tech Gyan! CyberKID's Avatar
    Jul 2010
    New Delhi
    Difference between GS and TX Series
    CORSAIR GS Series:
    GS Series™ power supply units are the ideal price-performance solutions for gamers who want stylish, high-performance PSUs for their next PC builds or upgrades. With 80 PLUS® Bronze efficiency, rock-solid voltages and switchable internal LED lighting, Corsair Gaming Series PSUs look as good as they perform.
    CORSAIR TX Series:
    Corsair TX Series™ power supply units are designed for hardcore PC gamers, performance enthusiasts, and anybody who appreciates a combination of high performance standards and affordability. TX Series PSUs are 80 PLUS® Bronze certifed, and are available in both modular and non-modular configurations.
    So, the moral of the story is the GS series is aimed at the average gamer, who wants the best performance with the good price, and at the same time, wants appealing looks too, while the TX series addresses the requirements of people like Hardcore Gamers, who have very power hungry systems, with high performance graphics cards in SLI and CrossFireX, often these people have a tri or a quad Graphics Card configs running on their systems.
    I'm a KID in this BIG Cyber World!
    Intel C2D E4500|CM Hyper TX3 EVO|Corsair VS450|MSI G41M-P26|Kingston VR 2 x 4GB DDR3 1333 MHz|Seagate 500 GB SATA 3.0+ WD 80 GB IDE|AOC E2243Fw2k|| Dell Inspiron 14R|Core i5 480M 2.66|WD 320GB SATA 3.0|6GB DDR3 1333|Philips SHP 2700|Microsoft Mobile 1000||Nokia C6-00
    My Blog: http://www.metro-greens.in
  6. #6
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    Get a good 650Watt PSU, which would be more than enough for your system regardless the amount you overclock it.
    IMO, Get Corsair TX650V2 @~5.5K
    Oh another thing, strictly avoid FSP.
    Inactive in TDF.
  7. #7
    Aug 2012
    Pune
    Quote Originally Posted by d6bmg View Post
    I am already using Corsair 650TX V2 Thx for giving me confidence that 650TX V2 would be able to run my rig. with overclocking.
    I've overclocked my Asus HD7950 Direct CUII to 950MHz and i5 3570k to 4.4 GHz today... Did real time test by playing Witcher 2 (with ubersampling enabled and ultra settings) and Skyrim (with ultra settings) at 1080p. Played both of them for 2 hours continuously. Did run same benchmarks as well. System was totally stable. Temps were just normal.
    Graphic Card Overclock List and Discussion
    Do you think I can still push it ?
  8. #8
    Aug 2011
    Kolkata
    You did real time test by playing PC game(s)?
    Don't do that.
    After OC'ing CPU to a particular level, run stress test using prime95 for at least 2 hours and check the temperature.
    After OC'ing GPU to a particular level run Kombuster which comes with MSI afterburner. You need to manually adjust GPU fan speed for higher overclocking.
    Refer to any good overclocking guide available in many good sites for more details.
    Inactive in TDF.
  9. #9
    knocking on heavens door sumonpathak's Avatar
    Jul 2011
    Skeleton city
    ^^erm...beg to differ my boi.....if it survives BF3 maxed out its stable.....or vantage looped 5 runs...
    ran kombustor @950..BSOD in 5 min...ran again in 1025....3HRS stable...go figure
    if you really want to change..get a AX psu
    2500K|3570K|FX-8150|FX-8350|965BE|E7500
    MVF|P8Z77-V Deluxe|P8Z68 Deluxe|CHV|880GM-USB3|M4A785T-M|G31M-ES2L
    HD7850|GTX660Ti|HD6870|HD6670|HD5450|9400GT
    HyperX Blu|HyperX Predator|RipjawsX|Value Select|CGM2X2|
  10. #10
    Aug 2012
    Pune
    @sumonpathak - Nah... let me save the money for something else which I could find of interest. AX is priced way to high
    @d6bmg - As I said... I did run benchmarks as well... 3dMark Vantage, Prime95, Kombuster, aida64 and cinebench. Was doing this thing for the whole of the day today..
    For me "real time test" means the exact situations under which I will be using the system for prolonged hours... i.e. I wont be running say prime95 for 2 to 3 hours daily but I'll be playing games for extended periods of time on weekends which I tested for all the time.
    Having said that... even after running stress tests and benchmarks, system was stable. Maximum temp recorded for GPU was 65 degrees and for CPU it was 67 degrees. Idle temps are 35 for CPU and 38 for GPU.
    Seems DirectCUII works very well for GPU (although not as good as IceQ). CM Hyper 212 Evo is also running good in push-pull config. And above all Silverstone RV03 is really giving great air-flow for these two coolers.
    One question --- Shall I run Furmark to stress test my GPU ? Have heard that it can burn the GPU sometimes.. so have never used it till date.
  11. #11
    Jul 2011
    Skeleton city
    no farmark plx
  12. #12
    Aug 2011
    Kolkata
    Neah! Avoid furmark.
    @sumonpathak: As you say my lord!
    Inactive in TDF.
  13. #13
    Jul 2011
    Skeleton city
    o btw...2500K on D14..5 ghz BF3 stable
    beat that...
  14. #14
    Aug 2011
    Kolkata
    Quote Originally Posted by sumonpathak View Post
    beat that...
    Very few, who have better chip than you can. Semi-golden chip, you, lucky one!
    Inactive in TDF.
  15. #15
    Nov 2007
    Bangalore
    Why exactly mate?
  16. #16
    Aug 2011
    Kolkata
    Quote Originally Posted by Xccentricity View Post
    Why exactly mate?
    Present and future availability (or lack of) and therefore RMA issue.
    Inactive in TDF.
  17. #17
    Aug 2012
    Pune
    hmmm... I've never tried anything other than Corsair & Antec.
  18. #18
    Nov 2007
    Bangalore
    FSP PSUs are hard to come by. Got my Saga II 500w after extensive searching in SP Road. Btw, who handles FSP RMA?
  19. #19
    Jul 2011
    Skeleton city
    ^^aditya..mainly....
  20. #20
    L33+ P$yCh0 Chaitanya's Avatar
    Jul 2011
    Paradise City
    Talking Re: Suggestions for PSU
    Quote Originally Posted by rocknrollasandy View Post
    I think the best psu considering your requirement is Antec TPQ850. It is one of the Best PSU when it comes to overclocking. Below is the link of its review:
    Antec TruePower Quattro (TPQ-850) 850W Review
    It has given rating of whopping9.5 out of 10 to this awsome psu. I dont have this one but i am using Antec EA500 on my rig.
    Regards,
    Rocknrolla
    Then what about this baby??
    Corsair AX1200i 1200 W Review | techPowerUp
    See the point is not the best of lot, it is best of lot within budget & availability
    :P
  21. #21
    Alpha Geek koolent's Avatar
    Oct 2010
    Rawatbhata, Kota, Rajasthan
    1200i is the totally best one, since its launch, it has been flying off the shelves ! ,
    What else clould you possibly want when you get the platinum certification and the total control of the 'monster in a cage' from your PC with windows online itself.!!
    Intel Core 2 Duo @ 2.8 GHz, Corsair CX430 v2, 3 GB DDR 2 RAM, MSI R6770 MD1GD5 (finally), MSI MS-7525 (v1.0), Compaq W185q 1366 X 768 HD LED Monitor
  22. #22
    Aug 2011
    Kolkata
    link of its review:
    Regards,
    Rocknrolla
    Totally OT, when the purpose of this thread has been fulfilled.
    Inactive in TDF.
  23. #23
    Aug 2012
    Pune
    ^^ Is there any way we can mark the threads as solved/completed or something like that so we can avoid further discussions on the thread ?
    Config : i5 3570K | Corsair H80 | Maximus V Formula | 2x8GB TridentX 2400 CL10 | Corsair 3 60GB | Barracuda 1TB | Razer DeathAdder 3.5G | Logitech G110 | Asus DC II HD7950 + Sapphire HD7950 Dual-X CrossFireX | AOC e2352Phz | Corsair AX850 | Raven RV03
    Audio : JBL Creature III 2.1 | Razer Megalodon 7.1
    Others : HTC Once X | Galaxy Tab P1000 | HP Pavilion 14-b104au Sleekbook | XBOX 360
  24. #24
    Aug 2011
    Kolkata
    Just report the 1st post of the thread and request mods to close the thread.
    Problem solved.
    Inactive in TDF.
