Results 1 to 10 of 10
  1. #1
    adi
    adi is offline
    Aug 2012
    Default Updating old CPU for use with HDTV.
    Ans: HD Movies, net surfing, Microsoft Office suite
    2. What is your overall budget? If you can extend a bit for a more balanced configuration, then mention this too.
    Ans: 2-3K. can be extended if its value for money
    3. Planning to overclock?
    Ans:No
    4. Which Operating System are you planning to use?
    Ans: Windows xp
    5. How much hard drive space is needed?
    Ans: I have 160 GB HDD. So not needed.
    Ans: I will use my HDTV as monitor, model : samsung 43E490 (720p). only HDMI Port, no VGA.
    Ans: Mother board : Mercury PI845GLM-L
    Processor : P4 2.8GHz
    RAM : 256 MB
    HDD : 160 GB
    DVD writer : Samsung
    8. When are you planning to buy the system?
    Ans: ASAP
    Ans: Assembler
    Ans: Gurgaon. Can buy from delhi or online.
    Ans: I need a GPU which can be used with my old mobo and processor so that it can be used with TV through HDMI port. currently my CPU has only VGA port.
    I think i will also have to buy Cabinate and PSU as my old one is of Quantum (I was not able search model name online)
  2. #2
    ico is offline
    . ico's Avatar
    Jun 2007
    Bangalore
    Default Re: Updating old CPU for use with HDTV.
    You just want to buy a new graphic card? Since you mentioned your budget only to be Rs. 2-3 thousand.
    For that you need a PCI-Express slot which your motherboard doesn't have. - Mercury-pc.com - Mercury PI845GLM-L motherboard
    Basic information regarding graphic cards for newbies
    AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn) | 2 * 4 GB Corsair 1600 Mhz Value RAM | Corsair CX430v2 | NZXT Gamma | Dell S2240L 22" @ 1080p
    Intel i5-2500K | Asus P8Z68 Deluxe | 2 * 4 GB Corsair Vengeance | WD Caviar Blue 500 GB | CM Hyper 212 Evo | AMD Radeon HD 6950 2 GB | NZXT Tempest Evo | Corsair AX850 | AverMedia AverTV Capture HD H727
    Samsung Galaxy S2 | Mac mini (Late 2009) with OS X Mountain Lion, 10.8
    Pandaboard ES | OMAP 4460 SoC | 2 * ARM Cortex A9 cores | PowerVR SGX540 graphics
    Arch Linux amd64 | Ubuntu 12.04 amd64 + omap4 ARM | Windows 7 x64
  3. #3
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    You need to change your whole 'outdated' rig to connect PC to HDTV.
    There may be some PCI based graphic cards in the market, but they are totally useless. My suggestion would be not to use them.
    Inactive in TDF.
  4. #4
    Rubik's Uncle!! RCuber's Avatar
    Sep 2004
    ಬೆಂಗಳೂರು (Bengaluru)
    P4 cannot play high Bitrate 720p Videos even with a good GFX card. if your main objective is only HD movies.. then go for a dedicated media player.
    I had previously faced lot of shuttering on 720P videos on my old P4 System with a 7300GT GFX card.
    the cake is a lie
    621311.251521
  5. #5
    In The Zone kiranbhat's Avatar
    Feb 2011
    sirsi
    Quote Originally Posted by ico View Post
    +1
    add atleast 10000 more TO that and make a dualcore+gpu to play hdtv
    e5700+P5G41T-M LX+sapphireHD5670 DDR5 1gb+Transcend 3GB 1333Mh+wd 160gb
    HP ML115-G5
    DELL Inspiron mini 1018
    SAMSUNG Galaxy Y [COD Rom+kuro kernel+jellybean4.2 greaper]SonyEricsson k510i
    posted using tapatalk
  6. #6
    In search for Tech Gyan! CyberKID's Avatar
    Jul 2010
    New Delhi
    Quote Originally Posted by RCuber View Post
    Man! I'm using one and I use to watch Full HD (i.e. 1080p) movies on my system without any problems at all (that too with just onboard graphics only)
    I'm a KID in this BIG Cyber World!
    Intel C2D E4500|CM Hyper TX3 EVO|Corsair VS450|MSI G41M-P26|Kingston VR 2 x 4GB DDR3 1333 MHz|Seagate 500 GB SATA 3.0+ WD 80 GB IDE|AOC E2243Fw2k|| Dell Inspiron 14R|Core i5 480M 2.66|WD 320GB SATA 3.0|6GB DDR3 1333|Philips SHP 2700|Microsoft Mobile 1000||Nokia C6-00
    My Blog: http://www.metro-greens.in
  7. #7
    Sep 2004
    Strange.. My issue must be the videos with high bit rate. but still I wont recommend P4, now a days even 6K tablets can play 1080P videos via HDMI
    the cake is a lie
    621311.251521
  8. #8
    Alpha Geek reniarahim1's Avatar
    Jan 2008
    Bangalore(KA) / Cochin(KL) , IND
    845GL motherboard struggles to play even 720p rips. PCI graphics card also wont serve the purpose. u can get an amd fusion combo motherboard but then also you need to get new ram stick and hard disk.
    Dell Studio 1555 - Intel Core 2 Duo P8600 @ 2.40 GHz, 3 GB RAM, 500 GB HDD, ATI Mobility Radeon HD 4500 | PC - Intel Pentium G620 @ 2.60 GHz, Intel DH67CL, 4 GB RAM, 500 GB HDD | Samsung Galaxy S Plus - 1.4 Ghz, 512 MB RAM, 16 GB Internal, 8 GB SD
  9. #9
    Aug 2011
    Kolkata
    I think weshould wait for the 2nd post of OP before discussing this issue any further. (if you what I mean)
    Inactive in TDF.
  10. #10
    Fast 'N' Furious topgear's Avatar
    Jul 2006
    Geek's Heaven
    Quote Originally Posted by reniarahim1 View Post
    I've played 720P videos on a 845GL using a P4 2.4 Ghz cpu - use KMPlayer and set OLD video Render as video renderer.
    @ OP - increase your budget and try to get a H61 mobo + Pentium G620 cpu + 2GB DDr3 ram - cost would be ~7k.
    BTW, you may also need to opt for a Sata HDD or else you can get a AMD 760G based mobo ( Asus or GBT ) with IDE port and Athlon II X2 cpu and Ddr3 ram.
    Who Dares Wins
    Avenging Angel !
    Phenom II 955BEAsus M5a97 R2.0Corsair 2x 4GB RAMHD6850Corsair GS600CM Hyper 212CM 430 Elite
    My Blog : http://topgeartopspeed.wordpress.com/
    BlackListed : Viewsonic, Gigabyte
