Results 1 to 13 of 13
Thread: Corsair cx430 v2 right for me?
11-08-2012, 06:22 PM #1Broken In
- Join Date
- Aug 2010
- Posts
- 197
First let me tell you why I m buying new PSU
I have 2-3 years old tagan 500w PSU. I have two Seagate HDD both 500 GB each one is old about two years and another is 10 months old .
I have problem with both HDD they both stop getting detected sometimes or start clicking. I send both HDD to Seagate for replacement but they won't detect any problems in it. So is it PSU related problem?
If u u feel this problem occurs due to PSU. I m planning to buy new Corsair cx430 v2
My current configuration is
AMD 840
Gigabyte 780G chipset mobo
Asus Ati 5770 GPU
2x 500GB sata
2x 2GB DDR 2 RAM
Is Corsair cx430 v2 is enough for me?
11-08-2012, 09:01 PM #2
Re: Corsair cx430 v2 right for me?
No idea about your problem but CX430 v2 is enough for your system..
12-08-2012, 12:39 PM #3Broken In
- Join Date
- Aug 2010
- Posts
- 197
Thanks for replying. Is there is any chep vfm PSU available instead of cx430 v2 ?
I m from Mumbai is it good to purchase your online from primeabgb or itwares or go to directly to local shop @ Lamington road.
12-08-2012, 12:42 PM #4
Corsair VS450W. primeabgb and E-lounge (ITWares) are brick and mortar shop. go and buy directly from them.
12-08-2012, 06:00 PM #5Right Off the Assembly Line
- Join Date
- Nov 2011
- Location
- Mangalore
- Posts
- 30
12-08-2012, 07:02 PM #6
CORSAIR Builder Series CX430 V2 430W ATX12V v2.3 80 PLUS Certified Active PFC Power Supply
costs same at Prime too(Rs.30 appx difference)Follow me on Twitter: http://twitter.com/wuodland
Have a look at my Photography page: http://bit.ly/N2aMTi
12-08-2012, 07:08 PM #7Right Off the Assembly Line
- Join Date
- Nov 2011
- Location
- Mangalore
- Posts
- 30
http://www.theitbazaar.com/store/our...category_id=43
Is it safe buying from this site?
12-08-2012, 11:57 PM #8
31-08-2012, 07:49 PM #9
Kindly suggest whether Corsair CX430V2 would be sufficient for running following config.:
Intel Core i5 3550 (Socket 1155) processor
Corsair Vengeance 4GB @ 1600 MHZ
Intel DH67CL B3 / Intel DH77KC
WD Blue 500 GB HDD
Sony DVD-RW Drive x 2
Sony FDD
Dell ST2220L monitor
Microsoft Keyboard
Logitech Basic Optical Mouse
Altec Lansing BXR1221 speakers
Cooler Master Elite 310 Cabinet
Or should I go for CX500V2?
Is there any possibility of adding a GPU later with this PSU?Last edited by g_goyal2000; 02-09-2012 at 06:40 PM.
Dell Studio 1558, Intel i5 M430 @ 2.27 Ghz, 4 GB RAM, 1 GB ATI 5470 Mobility, 500 GB HDD, IDT HD Audio with Creative X-Fi MB software
02-09-2012, 06:40 PM #10
bump...
03-09-2012, 01:38 AM #11
03-09-2012, 02:48 PM #12Alpha Geek
- Join Date
- Apr 2012
- Location
- Delhi
- Posts
- 890
04-09-2012, 05:13 AM #13
CX500v21 can easily power up a GTX 560 Ti with core i5 3550 and for CX430v2 the max limit should be HD7850 for g_goyal2000.
@ ankit360 - try changing the sata data cables and use some different sata port on the mobo - this should fix your issue.Who Dares Wins
Avenging Angel !
Phenom II 955BE↔Asus M5a97 R2.0↔Corsair 2x 4GB RAM↔HD6850↔Corsair GS600↔CM Hyper 212↔CM 430 Elite
My Blog : http://topgeartopspeed.wordpress.com/
BlackListed : Viewsonic, Gigabyte
LinkBack URL
About LinkBacks
