Results 1 to 10 of 10
  1. #1
    Jul 2012
    Exclamation hd 6670 and intex psu
    i'm thinking of buying hd 6670 but i'm afraid that it will burn my psu and i cant afford a new psu (pocket money problem)
    so my question is
    will it be safe to use radeon HD 6670 1 GB DDR5 with my psu
    https://www.facebook.com/photo.php?f...8239941&type=1
    my pc specs are
    intel pentium e5400 @2.7 ghz
    motherboard - gigabyte g31m-es2l
    4 gb ram
    windows 7 32 bit
    monitor resolution 1366x768
    nvidia 9400 gt (current graphics card )
    and the second question is
    is hd 6670 compatible with my motherboard
    you guys can also suggest a better gpu if my cheap psu can handle it
    Thanks.
  2. #2
    Aug 2007
    Chinchwad Pune
    Default Re: hd 6670 and intex psu
    Your Motherboard has a PCI-E x16 slot so the card will run just fine.
    Your Link for PSU is broken.
    HD6670 is not a Power Hungry card so it may run on cheap stake PSU.
    Phenom II 955 BE | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Kingston v300 SSD 240 GB | Seagate : 1 TB | NZXT Phantom 410 | Sony Experia Neo V
  3. #3
    Jul 2012
    i've fixed link .. please check again
  4. #4
    Bon fo Gamin(G) 101gamzer's Avatar
    Aug 2011
    DxB
    I would recommend you to get a good PSU because it is an important part of your PC and its only an one time investment so you could add a GPU later after you save up the money
    Get an Corsair CX430V2 @2.7k it will be much cheaper if you can get it locally
    then you can buy your GPU later on
    Gaming RiG comin sooooon..|Acer Aspire 4730z|PSP 3004PB|PSP 3004 GT5 BLACK EDITION|Samsung Galaxy S III 16 GB|Samsung LB530|
  5. #5
    In search for Tech Gyan! CyberKID's Avatar
    Jul 2010
    New Delhi
    Can't say about the power output of the PSU. If in case, you buy the card, and the PSU isn't able to power up your system, you'll face frequent restarts. So, better play safe and, in my opinion, wait for some time, save up and get yourself a good PSU.
    I'm a KID in this BIG Cyber World!
    Intel C2D E4500|CM Hyper TX3 EVO|Corsair VS450|MSI G41M-P26|Kingston VR 2 x 4GB DDR3 1333 MHz|Seagate 500 GB SATA 3.0+ WD 80 GB IDE|AOC E2243Fw2k|| Dell Inspiron 14R|Core i5 480M 2.66|WD 320GB SATA 3.0|6GB DDR3 1333|Philips SHP 2700|Microsoft Mobile 1000||Nokia C6-00
    My Blog: http://www.metro-greens.in
  6. #6
    Jul 2012
    will there be diwali in my cabinet if my cheap psu doesnt support 6670 ???
  7. #7
    Jul 2010
    New Delhi
    No, there will be no diwali in your cabby. just, it will be aftermath of diwali.
    if your psu isn't capable of powering up all your components, your system will simply restart due to shortage of power, nothing serious. But, please, in case you're considering going on to purchase a new psu, make sure it's a good brand. Make sure, you read this before going in for the purchase.
    I've got two (one mine and other my brother's friend's) mobos fried by a zebronics 450 watt psu.
  8. #8
    Jul 2012
    thanks cyberkid
    now i'll buy a good psu first and then i'll save for a mid range graphics card ..!
  9. #9
    Requiscat in Pace Gearbox's Avatar
    Jul 2012
    \home\office\
    Quote Originally Posted by iSachin View Post
    Thats so funny. Low power PSU means 'you cant even celebrate diwali'.
    Reality is always controlled by the people who are the most insane.
  10. #10
    Jul 2010
    New Delhi
    glad to be of help. yup, a psu is the most vital ORGAN of the computer system. it'll be good to purchase a good psu for now, save up, and get yourself a decent midrange GPU.
    Anyways, best of luck for the purchase.
    Quote Originally Posted by Gearbox View Post
    by diwali he meant the system going off KABOOM......
  1. Need psu for 6670 1gb ddr5
    By karan.bhambri in forum Power supply / Cabinets / Mods
    Last Post: 13-02-2012, 03:19 AM
  2. HD 6670 in PCI E 1.1
    By sukesh1090 in forum Graphic cards
    Last Post: 16-06-2011, 01:30 PM
  3. about new amd 6670
    Last Post: 04-05-2011, 11:15 PM
  4. help opera for 6670
    By suyash_123 in forum Internet & WWW
    Last Post: 15-11-2006, 02:50 PM
