Results 1 to 30 of 31
10-04-2012, 06:43 PM #1Right Off the Assembly Line
- Join Date
- Jun 2011
- Posts
- 18
New cabinet with good cooling and lots of space
Hey folks,
My current config:
Intel Core i7-950 (D0)
Corsair XMS DDR3 8 GB
GA-X58A-UD7(Rev 2.0)
Seaagte 1TB ST31000524AS + Samsung SP0822N
Zotac GTX 470 1280mb
I have a Zebronics Bijli (1st edition) cabinet
which is very poor in terms of cooling and has very little space to accomodate all hardware with a long GPU.
Pls suggest a new cabinet ideal for this config. I might also want to upgrade to Liquid cooling in the future
, so please consider that. Also recommend a good quality PSU as i currently have a cheap VIP 600W PSU. It should be able to handle at least 2 way SLI.
10-04-2012, 06:49 PM #2
Re: New cabinet with good cooling and lots of space
Budget for cabinet & SMPS separately?
Gaming Rig:i7 2600K | N620 | P8Z68 Deluxe | 2x4GB RipjawsX DDR3 1600 | Vertex 3 120GB | Logitech G510 | Logitech G400 | Sapphire 6950 1GB | BenQ G2420HD | Corsair HX750 | Lancool K62
HTPC Rig: C2D E7400 | EP45-DS3R | 2x2GB DDR2 800 | MS Wireless Desktop 2000 | Gigabyte 5770 | Samsung 32" | Seasonic SII 520W | Silverstone LC10
Audio Gear: Altec Lansing VS2421 | ASUS Vulcan ANC | HiFiMan RE-0
Storage: 2x250GB | 3x500GB | 3x1TB | 3x2TB
Android: Galaxy R | Galaxy Y
10-04-2012, 08:06 PM #3Right Off the Assembly Line
- Join Date
- Jun 2011
- Posts
- 18
PSU is not of great priority now. 1st thing that I need is a good cabinet. I was considering the NZXT Phantom Full tower.
10-04-2012, 08:57 PM #4
If you are thinking of phantom then u should have a budget of atleast 9k. Phantom is a great cabby. You can also look for corsair graphite 600t. But currently your first priority should be the psu. U are running on a time bomb!!
10-04-2012, 09:24 PM #5Right Off the Assembly Line
- Join Date
- Jun 2011
- Posts
- 18
I thought the Phantom full tower was available fr around 6k in lamington rd. It looks xtremely impressive. The 600T seems to be v.good according to numerous reviews. Any other good ones? Theres a huge range and i just cant decide.
People told me that. But why?
that my psu was a time bomb
10-04-2012, 09:34 PM #6
because it is a local unreliable PSU on which you are running a power hungry card and thinking of checking your PSU's explosion capability by adding another 470.so better buy a good 600w psu at around 4k.
btw the nzxt phantom which is available at 6k is phantom 410 and is not a full tower but still looks and feels like its elder brother.for cheap water management case you can go for 400R but if and only if you are planning to buy corsair H100 or cooler with similar dimensions or thinner.you will have problem with DRAm slots if you buy a radiator thicker than H100.
It will help us a lot if you fix your budget and let us know it.Spoiler:
" Behind this mask there's more than flesh Mr.creedy, behind this mask there's an Idea and ideas are bulletproof. " - V for Vendetta.
10-04-2012, 10:12 PM #7Right Off the Assembly Line
- Join Date
- Jun 2011
- Posts
- 18
Thanks for your replies everybody. Budget is yet not fixed, but the final cost can always be reduced by around 2K coz the people at lamington rd are reasonable. Basically I want my rig to be extremly neat and good cable management and good airflow. My GPU runs @ around 70c idle without overclocking(factory overclocked card), which is why i wanted liquid cooling. Forgetting all previous requirements, should i first buy a PSU or cabinet looking only at my current config, coz overheating could damage my rigs parts, and my Bijli is a faliure at any kind of cooling. Please recommend only cabinets with long GPU support, coz its a big pain to have 2-3 hdd slots blocked
10-04-2012, 10:16 PM #8
I would suggest phantom 410 and corsair 750tx which will be under 15k.
10-04-2012, 10:19 PM #9Right Off the Assembly Line
- Join Date
- Jun 2011
- Posts
- 18
Hmmm. Any cheaper alternatives not compromising on quality? Anyways, I feel that the 410 looks cheap compared to the full tower
10-04-2012, 10:22 PM #10
If not the phantom then you can get the 690 2 advanced or carbide 500r. Both will be under 7k.
10-04-2012, 10:43 PM #11Right Off the Assembly Line
- Join Date
- Jun 2011
- Posts
- 18
carbide 500r looks good. Ill probably go for it. Is it available in lamington coz people complained of its inavailibility in India.
btw my PSU recommendation is 490W according to CoolerMaster PSU calculator
10-04-2012, 10:57 PM #12
ditch that calculator and go for a 600 or 700W psus as it will be there with you for some time in future and you are thinking about SLI.go for 500R its a great cabinet.
10-04-2012, 11:11 PM #13Right Off the Assembly Line
- Join Date
- Jun 2011
- Posts
- 18
What abt gx650?
Will my comp seriously blow or i could upgrade my psu after ~2 months?
Thx
10-04-2012, 11:45 PM #14
Until and unless you are quoting your budget, its hard to recommend any particular model. Secondly, Coolermaster GX series is not that good.
11-04-2012, 06:54 AM #15
go for the 500r. Its spacious and has nice cable management. Plus if u can get the components from smc you can get glacialtech ax 900 under 7k. Its modular and has 80+ silver certification.
11-04-2012, 07:22 AM #16
Better mention the approximate budget or this discussion will reach nowhere buddy.
AMD Phenom II X6 1605T | ASUS M5A88-M | G.Skill RipjawsX 1600MHz 4GB | MSI N560GTX-M2D1GD5 | Seagate Barracuda 1TB | SeaSonic S12 II 520 | BitFenix Merc Alpha | Asus DRW-24B3ST | BenQ G2222HDAL | Lenovo M6811 | Razer Goliathus Control Edition | Logitech K100 | Philips SHP1900 | F&D A-510
11-04-2012, 08:17 AM #17Right Off the Assembly Line
- Join Date
- Jun 2011
- Posts
- 18
Aproxx budget can only be decided after my exam results are out
screw the SLI part of my plan
13-04-2012, 08:33 AM #18Right Off the Assembly Line
- Join Date
- Jun 2011
- Posts
- 18
Finally i might take the plunge today
. Any final recommendations?
Ive thought of buying Corsair 500r and the PSU next week.
13-04-2012, 09:41 AM #19
hey hold your cabinet purchase till may because corsair has released new case vengeance at the same price point of 500R i.e., $139.99 and looks awesome.you may want to buy it.
Vengeance Gaming Cases ? designed for travelling gamers, with durable steel construction and high-airflow designs, they?re built for LAN party dominanceSpoiler:
13-04-2012, 02:04 PM #20
Go for it. The vengeance cases will take time to arrive at our shores. Also they are almost the same cases. So which psu have u decided?
14-04-2012, 08:59 AM #21Right Off the Assembly Line
- Join Date
- Jun 2011
- Posts
- 18
Rejoice!! NZXT Phantom Full Tower Available for 7k. Isnt that way better than 500r?
Also i think ill go for the TX750 non modular.
14-04-2012, 10:06 AM #22
I think that's a very good combo. Go for it.
14-04-2012, 10:43 AM #23
Yes way better. So go for it and best of luck.
14-04-2012, 12:04 PM #24Right Off the Assembly Line
- Join Date
- Jun 2011
- Posts
- 18
Thanks everybody for your help. Ill post pics of it when i get it. BTW, what colour should i take? I just love the white but it may get dirty soon(ie off white) which will be a pity. Also black inside the innards of the case would be amazing for cable management.
14-04-2012, 12:51 PM #25Wise Old Owl
- Join Date
- Aug 2007
- Location
- Chinchwad Pune
- Posts
- 1,438
Black Case with Blue LEDs looks cool for my taste.
Phenom II 955 BE | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Kingston v300 SSD 240 GB | Seagate : 1 TB | NZXT Phantom 410 | Sony Experia Neo V
14-04-2012, 05:17 PM #26
If you want some eye candy then the red one. The black can cover bad cable management easily!
14-04-2012, 07:39 PM #27
my vote for tech_wiz idea.black with red light will look amazing.
14-04-2012, 10:34 PM #28Right Off the Assembly Line
- Join Date
- Jun 2011
- Posts
- 18
Finally got my white Phantom full tower with GS800(TX750 was not available n i thought gs800 would suffice). Its just great and HUUUge. I bought it from prime abgb, and their service was excellent. Honestly, its the first time i have ever seen such a huge and good looking cabinet. I was stunned when i saw it for the 1st time. Btw, my gpu now idles @ around 50c n my cpu @around 45c.
14-04-2012, 10:48 PM #29
Congos.
And post some pics here:-
http://www.thinkdigit.com/forum/show...-purchase.htmlGaming Rig:i7 2600K | N620 | P8Z68 Deluxe | 2x4GB RipjawsX DDR3 1600 | Vertex 3 120GB | Logitech G510 | Logitech G400 | Sapphire 6950 1GB | BenQ G2420HD | Corsair HX750 | Lancool K62
14-04-2012, 11:05 PM #30Right Off the Assembly Line
- Join Date
- Jun 2011
- Posts
- 18
Phantom full tower - 7.5k
CM GS800 5.9k
New cabinet for cooling under 2.5k
By aytus in forum Hardware Q&AReplies: 10Last Post: 28-04-2009, 09:44 PM -
Gigabyte Liquid Cooling & Cabinet
By Jayanth.M.P in forum Hardware Q&AReplies: 22Last Post: 17-03-2007, 10:57 AM -
Place in Bangalore where cooling solution & fancy looking cabinet for PC r available
By kirangp in forum Hardware Q&AReplies: 8Last Post: 08-02-2007, 11:14 PM -
Help me with my cabinet cooling fan problem.
By Kannan in forum QnA (read only)Replies: 8Last Post: 23-01-2005, 11:21 PM -
amd64 mobo, cabinet, cooling, and power supplies
By maxxxee in forum CPU / MotherboardsReplies: 4Last Post: 21-10-2004, 08:54 PM
LinkBack URL
About LinkBacks
