Results 1 to 13 of 13
Thread: Power Supply Need
15-11-2011, 09:53 PM #1Alpha Geek
- Join Date
- Jun 2008
- Posts
- 610
Power Supply Need
Hi I am in real confusion that most of the power supply is only 70-90% efficiency. But we cannot calculate these and buy a powersupply . Say a system need 500 watts we could buy 550 watts or max 600 watts. Let it be a idle load or full load when it attains peak we can determine say process hungry apps we may use daily or some rare occasions. As we need to be prepared. But in most cases the gpu manufactures do not say the actual consumption of the card in real load instead say the total pc power . Which also not specific. As there are Bronze certified , Silver certified, gold certified. Which are variable efficiency. Doesnt mean that they cant provide full capacity but will have some ups and down. I had read few forums on PSU review say the are able to get more wattage than mentioned but in practical the rated is just a safer side and optimal output which over long run would not damage any component.
No such proper tools to measure what the delivering wattage of the pc. Is there any manufactures giving a feature to display the total consumption of load it should be a must feature . They say its certified how do a end user measure it. there need to be a point where we can measure or a tool to display or atleast board manufatures should be able to calculate. even its impossible to do in certain scenarios .As costing will increase a bit as well many may not welcome due to costing factor but gamers and enth people who wanted to know what we are going to use we can get it. Buying one and not able to use in long run is merly a waste of money.Intel I5 2500K@4.3GHZ OC : Corsair Force 3 SSD 120gb: GSKILL 8GB 2X4GB 1600MHZ: Asus P8Z68 V: ZOTAC GTX 560TI 1GB DDR5:CORSAIR GS800 :Corsiar 400R :Asus Xonar DX 7.1 AC: NZXT SENETRY2 :CORSAIR H100: LG E2360V 23" : Logitech MX518:
15-11-2011, 09:59 PM #2
Re: Power Supply Need
there are reputable websites as well as forums which post detailed reviews of good ,not so good & bad PSU s. They have the equipments required but it will be a waste money for a normal home-PC user to get those costly equipments to measure power consumption.
15-11-2011, 10:39 PM #3Alpha Geek
- Join Date
- Jun 2008
- Posts
- 610
I agree if a mf can set a standard in the psu to add as aditional functionality it would be great. Future computing is going to be power conscious. As every other fuel is becoming costly only left is power will also likely to hike in near future as all demand keeps on growing
15-11-2011, 10:42 PM #4
The best indicator of the Power will be from the wall socket itself because there is UPS too between the Computer Power supply and the main power and it has variable power efficiency too.
Appreciate me now and avoid the rush!!
i5 2500K || 8GB DDRIII 1600 MHz RAM || Zotac GTX560Ti || Samsung 2233sw || Corsair GS600
15-11-2011, 11:55 PM #5
i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - Plextor M3 PRO 128GB - 1TB 7200.12 - GTX 570 sonic platinum - CM M600 - HAF X - XONAR DX + VS4121/XB500 - OptX AW2210 - DSL 2750U - Micro 800va
16-11-2011, 01:34 AM #6Alpha Geek
- Join Date
- Jun 2008
- Posts
- 610
As I am thinking of going for high power gpu later after seeing CF will do the neat job and so i can save some extra amount if i need to invest for 15+ card will also be old after 1 year . But this setup will it be suffice for atleast 1 year. I will buy good card later next year
16-11-2011, 02:08 AM #7
Replace your CM Extreme Power Plus 600w please. It sucks.
AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn)
| 2 * 4 GB Corsair 1600 Mhz Value RAM | Corsair CX430v2 | NZXT Gamma | Dell S2240L 22" @ 1080p
Intel i5-2500K | Asus P8Z68 Deluxe | 2 * 4 GB Corsair Vengeance | WD Caviar Blue 500 GB | CM Hyper 212 Evo | AMD Radeon HD 6950 2 GB | NZXT Tempest Evo | Corsair AX850 | AverMedia AverTV Capture HD H727
Samsung Galaxy S2 | Mac mini (Late 2009) with OS X Mountain Lion, 10.8
Pandaboard ES | OMAP 4460 SoC | 2 * ARM Cortex A9 cores | PowerVR SGX540 graphics
Arch Linux amd64 | Ubuntu 12.04 amd64 + omap4 ARM | Windows 7 x64
16-11-2011, 07:58 AM #8
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
16-11-2011, 08:03 AM #9
^^ yup.
Example....an 80% efficient 800 watt PSU will deliver 800 watts with 80% efficiency.
This means, it will pull 1000 watts from the wall socket to deliver 800 watts to the computer.
200 watts get consumed during AC to DC conversion.AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn)
16-11-2011, 08:06 PM #10Alpha Geek
- Join Date
- Jun 2008
- Posts
- 610
As said I had upgrade to gs800. I am going to post in the show off sec soon. Not much photos but real videos. I missed taking the photo of gpu.
One thing sucks is the hdd sata power is one single long cable which really sucksIntel I5 2500K@4.3GHZ OC : Corsair Force 3 SSD 120gb: GSKILL 8GB 2X4GB 1600MHZ: Asus P8Z68 V: ZOTAC GTX 560TI 1GB DDR5:CORSAIR GS800 :Corsiar 400R :Asus Xonar DX 7.1 AC: NZXT SENETRY2 :CORSAIR H100: LG E2360V 23" : Logitech MX518:
16-11-2011, 09:29 PM #11
^^But'um why GS800 ? Whats ur budget?
21-11-2011, 11:25 PM #12Alpha Geek
- Join Date
- Jun 2008
- Posts
- 610
No mega as i already had a gr8 effect over the psu. So went the decent one. Not big but little bite on pocket. Its fine when you need a decent rig without issues need a better psu. Its might be an overkill as of now but long run when i run 7 series card this will become bare minimum. SO i went for it.
I had one query even when i run low power consumption will still be wasting so much of power. As i am now worried will i be wasting power with this psu. Though its 85% only at consumable power right.Intel I5 2500K@4.3GHZ OC : Corsair Force 3 SSD 120gb: GSKILL 8GB 2X4GB 1600MHZ: Asus P8Z68 V: ZOTAC GTX 560TI 1GB DDR5:CORSAIR GS800 :Corsiar 400R :Asus Xonar DX 7.1 AC: NZXT SENETRY2 :CORSAIR H100: LG E2360V 23" : Logitech MX518:
22-11-2011, 05:56 AM #13
What i was trying to say is, 'why GS series, TX would be better'
Here is the answer for ur ques.i5 2500K - P8Z68-V - Venomous X - RipjawsX 8GB 1600Mhz CL8 - Plextor M3 PRO 128GB - 1TB 7200.12 - GTX 570 sonic platinum - CM M600 - HAF X - XONAR DX + VS4121/XB500 - OptX AW2210 - DSL 2750U - Micro 800va
power supply for 2k
By sukesh1090 in forum Hardware Q&AReplies: 7Last Post: 12-05-2011, 03:17 AM -
which power supply ?
By ankit0_0 in forum PC Components / ConfigurationsReplies: 6Last Post: 07-03-2011, 05:17 PM -
Power supply
By kumarn_2004 in forum Hardware Q&AReplies: 1Last Post: 24-12-2006, 08:43 AM -
Getting the right Power Supply
By gxsaurav in forum QnA (read only)Replies: 29Last Post: 09-10-2005, 02:18 PM -
AMD 64 Power supply
By impetus in forum CPU / MotherboardsReplies: 4Last Post: 18-01-2005, 11:59 AM
LinkBack URL
About LinkBacks
