Results 121 to 150 of 836
16-09-2009, 08:19 AM #121
Re: Basic guide for the right power supply
I think VX450 will be able to do the job perfectly as FX-580's max power requirement is 40W.
Samsung Galaxy S3 running cm10.1 nightly, Samsung Omnia W, Thinkpad T430 (Core i5, 8GB RAM, 160GB SSD, 14" 1600x900,9cell battery). Desktop: AMD Athlon X2 7750 BE, 4GB DDR2, 1TB HDD, 2600XT, 19" LCD
16-09-2009, 12:40 PM #122Right Off the Assembly Line
- Join Date
- Sep 2009
- Location
- india
- Posts
- 3
@desibond
Thnx for Reply... I think so its at 40W,and if switching to Quadro FX-1800,then it's 59W.
Actually I was Concerning about the Whole Rig-setup.
So can someone tell me in my rig how much ' Total Power ' is to be Consumed ?
----------------------------------------Last edited by theuser; 16-09-2009 at 12:45 PM. Reason: Automerged Doublepost
16-09-2009, 01:35 PM #123
@ theuser
http://www.thermaltake.outervision.com/DEATH IS OUR BIRTH RIGHT - SO Y FEAR DEATH ???
16-09-2009, 05:10 PM #124Right Off the Assembly Line
- Join Date
- Sep 2009
- Location
- india
- Posts
- 3
@damngoodman999
Thank you for that link
23-09-2009, 08:01 AM #125
Massive bump for the crowd
25-10-2009, 12:12 AM #126
My current PC configuration :-
Intel Core2Quad Q8200 @ 3.15GHz (OC)
Asus P5Q Mobo
Asus triton 77 cpu cooler
4 x 2GB DDR2 @ 800MHz (Transcend)
Seagate 500GB x 2
XFX GeForce 9600GT
Cooler master CM 690 Chassis
PSU : Zebronics platinum series 600W (System has been working just fine.)
I recently got a new GFX card XFX GTX 260 BE 216 for which i require a PSU with at least 40A current output on the 12V rail and 2 x 6-pin PCI express connectors, i was planning on buying the Zebronics platinum series 800W as its the only brand of decent PSU i could find in my city (Bhubaneswar). Well but i have decided not to after reading this so i need a suggestion for a good PSU for the system. I'm planning on upgrading the system to i7 920 + Asus R2Gene + 6GB DDR3 + XFX GTX 260 BE (maybe also SLI it in future) so i need a good PSU that i can use for the new build. I have a max budget of 10k for the PSU so guys plz suggest a good PSU. Thx ^_^Last edited by ShyamaC177; 25-10-2009 at 12:59 AM.
25-10-2009, 01:58 AM #127
I would wait for the nvidia's newer cards to launch if I were you, but if you must buy, then get the Palit GTX260 SONIC @ 10.5k.
Hmmm... PSU. I suggest modular PSU's for better cable management. Corsair HX620W is a good option @ 7.4k. Can easily handle all that you plan to throw. For OCing, consider the Corsair TX750W or Tagan BZ700, both under 10k AFAIK.Neo TDF > TDF 6.5
Ignorance of FORUM RULES is no defence.
27-10-2009, 05:05 PM #128
Well I got myself a Corsair HX620 from eBay, I guess it will be good enough for my current system.
Intel Core i7 920 @ 3.4GHz (OC)
Asus P6T | CM Hyper 212 Plus | Zion 3 x 2GB DDR3 @ 1333MHz
XFX Geforce GTX 260 BE 216
Seagate Sata2 2 x 500GB + 2 x 1TB
Corsair HX 620 | Cooler Master CM690
27-10-2009, 06:28 PM #129
^^ even a vx550 will be more than sufficient.
27-10-2009, 06:37 PM #130
^How about HX520? I like modular PSU's more.
Neo TDF > TDF 6.5
27-10-2009, 08:17 PM #131
^^ Wasted- unless one gets hx 620 for 6k just like back in the good old pricing days.
27-10-2009, 08:22 PM #132
^Its 7.4k now right? Why did the prices of PSU's bloat so much?
Neo TDF > TDF 6.5
27-10-2009, 08:25 PM #133
^^ The law of demand and supply. There's only 1 main distri now since TAG ditched corsair.
27-10-2009, 08:36 PM #134
Damn! Corsair should get another distri soon (else we're done for)!
Neo TDF > TDF 6.5
27-10-2009, 09:04 PM #135
^^ Even if corsair get another main distri, its not necessary they will bring the price down. Like I said- law of demand and supply. I bought my tx750 from prime under 7k during the time when vx450 was sold as cheap as 3.2k all inclusive.
27-10-2009, 09:09 PM #136
That was indeed a super buy. Just my luck! 3.9k for VX450W!
Neo TDF > TDF 6.5
27-10-2009, 09:57 PM #137
21-11-2009, 09:32 AM #138
Bump with minor updates.
02-02-2010, 05:05 AM #139Right Off the Assembly Line
- Join Date
- Mar 2004
- Posts
- 1
Hi there,
I have decided to add an HD 4850 1Gb to my 2 year old pc.
Core 2 Duo E 7200
Intel DG31 PR
4 GB DDR 2 800 Transcend
1x 1 TB Seagate 7200.12 SATA
1x 160 GB Samsung Sata
1x Philips SPD2517T DVD RW
1X Dax Fast Ethernet PCI Card
I have a 19 inch monitor so the max res i would be playing games in is 1440x900
Since I live in Kerala and none of the big brands (Corsair,CM,Antec etc) are available I am thinking about the I ball Sprinter 600 from their high-end range, the only other option (that sounds decent) is a VIP 600 watt. Iball offers 3 year warranty.
Has anyone used these models ? If so kindly help me choose the lesser of the two evils.
And before anyone suggest buying from the Internet is not an option (after several bad experiences). I will get the components of my next PC from a metro, but really do not feel like traveling to pickup a PSU.
08-10-2010, 12:43 PM #140
Thread unlocked and stuck.
Note: All threads created prior to 2009 were locked to avoid spam bumps.AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn)
| 2 * 4 GB Corsair 1600 Mhz Value RAM | Corsair CX430v2 | NZXT Gamma | Dell S2240L 22" @ 1080p
Intel i5-2500K | Asus P8Z68 Deluxe | 2 * 4 GB Corsair Vengeance | WD Caviar Blue 500 GB | CM Hyper 212 Evo | AMD Radeon HD 6950 2 GB | NZXT Tempest Evo | Corsair AX850 | AverMedia AverTV Capture HD H727
Samsung Galaxy S2 | Mac mini (Late 2009) with OS X Mountain Lion, 10.8
Pandaboard ES | OMAP 4460 SoC | 2 * ARM Cortex A9 cores | PowerVR SGX540 graphics
Arch Linux amd64 | Ubuntu 12.04 amd64 + omap4 ARM | Windows 7 x64
08-10-2010, 09:22 PM #141
well this is a nice thread
now kids wont go for desi brands or extreme PSUs
08-10-2010, 09:37 PM #142
Update:
I have removed the list of recommended power supplies for a good reason. Not only that its outdated but also the quality of the newer vx, tx and hx series of corsair power supplies have degraded compared to the older ones. Whether they are still reliable or not is something I can't really say as I've extremely less resources to test/confirm that and its just not possible to get hands on stuff everytime an established model/series gets a new production batch with "minor changes". As far as my trusted source of information through a knowledgible friend goes, vx450's 3v and 5.5v doesn't live upto its usual load and as far as I've seen, TX750's 3.3v, +5v and +12v is overpowered.
All I can say is do your research properly and notice the differences (you can assuming you help others to build systems on "special" occasions) by checking out the overall built quality, the sleeving, the thickness of the wire, the connectors, the power plug (you can never be too careful) and once you're plugged it in a system keep an eye on the rails and make a note of any problem on the fluctuation on idle and load. This is something that a genuine advisor can do it but people who copy-paste other people's advice couldn't. So therefore its best if such people refrain from advising others unless you did a proper research- or else you're simply damaging the community this way. There are websites like jonnyGURU, anandtech and hardware secrets make an effort to do a real and a proper review power supply with proper and proven methodology.Last edited by The Sorcerer; 08-10-2010 at 09:45 PM.
10-10-2010, 04:49 PM #143
Can you recommend me a power supply for the system specs in my sig.
I'm thinking of getting cooler master real power400w
But i want to keep my budget near 3k
10-10-2010, 05:42 PM #144
Gigabyte 460 superb or seasonic S12II-380. Comes under that price.
10-10-2010, 05:49 PM #145
10-10-2010, 06:22 PM #146
Corsair cx400 or antec EA430, but I am not sure about antec's rma policy/experience.
10-10-2010, 08:15 PM #147Wise Old Owl
- Join Date
- Sep 2010
- Posts
- 1,293
^^Wat abt FSP Saga II 450 or 500W?Those will also come within 3k,isn't it?Moreover they're the best VFM,aint it?
10-10-2010, 08:44 PM #148
But where will i get fsp from?
10-10-2010, 08:49 PM #149
Don't know much but as per what I've heard, so far its the fsp 350w viz decent. I don't know anyone who used and tested larger watt units yet. You're getting corsair cx400/EA430/Gigabyte 460 superb and seasonic s12 380 for that price, they are all good units and one or two units will be available easily, what's the point in recommending FSP? VFM means value for money and not "cheap". Not that I am saying its bad, but these units are better and worth for the price, ain't it?
Besides, how many have RMA experiences with FSP? 1....2?? How can one say its value for money without knowing it? I don't recommend stuff that way. As far as I've seen, most of the time corsair and seasonic are replaced rather then repaired (unless its really a minor issue).
10-10-2010, 09:19 PM #150
I'll see if i can get fsp otherwise i'll go for cooler master or corsair.
Just checked the wattage calculator of cooler master for my system and it showed 409w psu requirement for my system.
Sapphire amd ati HD 7770 or sapphire amd ati HD 7770 overclocked edition??? - Graphics & Displays
Refback This thread18-03-2013, 11:30 PM -
18-03-2013, 05:41 PM
Refback This thread13-03-2013, 08:47 PM -
23-02-2013, 11:51 AM
21-02-2013, 08:52 PM
28-01-2013, 08:10 AM
What type of PSU is Compatable with the GTX 660 - Graphics-Cards - Graphic-Displays
Refback This thread25-01-2013, 02:54 PM -
Refback This thread25-01-2013, 02:39 PM -
24-01-2013, 08:32 AM
18-01-2013, 11:55 PM
18-01-2013, 05:14 PM
18-01-2013, 03:47 PM
WILL THIS GRAPHICS CARD WORK ON MY PC?? - Page 2 - Graphics-Cards - Graphic-Displays
Refback This thread03-01-2013, 05:42 PM -
Refback This thread03-01-2013, 05:17 PM -
31-12-2012, 07:29 PM
31-12-2012, 12:04 PM
08-11-2012, 01:50 PM
Weird Display Problem
Refback This thread01-08-2012, 10:17 PM -
My new PC! - Page 3
Refback This thread12-07-2012, 04:59 PM
power supply
By rajkiran in forum QnA (read only)Replies: 2Last Post: 22-05-2008, 11:27 PM -
Power Supply
By gmanog in forum Hardware Q&AReplies: 36Last Post: 05-02-2007, 01:19 AM -
Power supply
By kumarn_2004 in forum Hardware Q&AReplies: 1Last Post: 24-12-2006, 08:43 AM -
ULTIMATE GUIDE:eXtreme Power Supply Calculator v2.0
By Kiran.dks in forum QnA (read only)Replies: 4Last Post: 22-12-2006, 01:28 PM -
AMD 64 Power supply
By impetus in forum CPU / MotherboardsReplies: 4Last Post: 18-01-2005, 11:59 AM
LinkBack URL
About LinkBacks
