Results 301 to 330 of 836
26-11-2010, 10:52 AM #301Right Off the Assembly Line
- Join Date
- Nov 2010
- Posts
- 21
Re: Basic guide for the right power supply
Okk..understood...
But the Zebronics PSU they were talking about was not for 500 bucks...
It was...
Zebronics Platinum Series 500 W PSU for 1950 bucks...
26-11-2010, 11:54 AM #302Wise Old Owl
- Join Date
- Sep 2010
- Posts
- 1,293
Ya you are right!Zeb 500W is for around 2k but that doesn't make it a reliable & good one.If you are on a tight budget then go for FSP Saga II 400W or Saga II 500W.
26-11-2010, 12:01 PM #303
exactly
go for the above PSUs
if they are also no available then try to search for Gigabyte 460W PSU....its too available for 2k
26-11-2010, 12:18 PM #304Right Off the Assembly Line
- Join Date
- Nov 2010
- Posts
- 21
I wanted to buy Gigabyte Superb 460W or the FSP Saga II 400 W ...but none of the shops have any of these two PSU's...
Now I don't think I've any other way other than buying it online...but I want to know the warranty policy first...
If it says that the product can be repaired locally(Kolkata) with the authorized service centers, then I am game for it...but if I have to send it back to their address from where I am buying..its very troublesome...
So if anyone who has bought products online can comment on this..it would be of great great help...
26-11-2010, 12:25 PM #305
^^contact asingh /sam.shab/jaskanwar/tkin/clius
they all recently purchased some stuff online
26-11-2010, 12:50 PM #306Right Off the Assembly Line
- Join Date
- Nov 2010
- Posts
- 21
Ok thanks...I will ask them..
Guys...I've finally learnt that I am neither gonna get FSP or Gigabyte from here...
So finally I've upped my budget to 2.8k..
now just tell me which one should I go for out of the two...no more queries from me after that...
1> COOLER MASTER EXTREME PLUS 500W
2> Corsair CX430W
Both are priced at 2.8k at MD Computers...and both are available..
now just tell me which one is the best bet...Last edited by preetamsikdar; 26-11-2010 at 05:33 PM. Reason: Automerged Doublepost
26-11-2010, 07:10 PM #307
cooler master extreme plus series is extremely crappy from the reviews i have read, dont know much about the cx430 tho
26-11-2010, 07:40 PM #308Wise Old Owl
- Join Date
- Sep 2010
- Posts
- 1,293
my vote for CX430!!Don't go for CM extreme series.
26-11-2010, 07:44 PM #309
26-11-2010, 07:52 PM #310Right Off the Assembly Line
- Join Date
- Jul 2010
- Posts
- 25
Hi
I have FSP Saga II 500W Power Supply and APC Back-UPS AVR Pro (8 Years Old).
Is there any conflict with these two ?
26-11-2010, 09:50 PM #311
26-11-2010, 10:16 PM #312
26-11-2010, 11:02 PM #313
You get what you pay for in the SMPS market i guess
26-11-2010, 11:03 PM #314Right Off the Assembly Line
- Join Date
- Nov 2010
- Posts
- 21
Okk thnx..
Will go for Corsair CX430W..
Thanks once again guys
27-11-2010, 12:17 AM #315
no. a Corsair CX400W cost 2.7-2.8k. a CM Extreme power 500W will cost almost same. whereas the Corsair unit is rock solid & provides well above 400W easily, the CM unit may need visit a RMA center if you load it up to 75-80% of the rating.
so, even if you pay a hefty amount, little research on the user's part is needed. not just PSU. any PC part.
27-11-2010, 04:50 AM #316
I don't remember why but isn't
CX400W>CX430W??
27-11-2010, 05:10 AM #317
No way CX430. CX430 isn't as good as CX400.
CX400 is the one you should buy.
Corsair's new CX "builder" series aren't that good.AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn)
| 2 * 4 GB Corsair 1600 Mhz Value RAM | Corsair CX430v2 | NZXT Gamma | Dell S2240L 22" @ 1080p
Intel i5-2500K | Asus P8Z68 Deluxe | 2 * 4 GB Corsair Vengeance | WD Caviar Blue 500 GB | CM Hyper 212 Evo | AMD Radeon HD 6950 2 GB | NZXT Tempest Evo | Corsair AX850 | AverMedia AverTV Capture HD H727
Samsung Galaxy S2 | Mac mini (Late 2009) with OS X Mountain Lion, 10.8
Pandaboard ES | OMAP 4460 SoC | 2 * ARM Cortex A9 cores | PowerVR SGX540 graphics
Arch Linux amd64 | Ubuntu 12.04 amd64 + omap4 ARM | Windows 7 x64
27-11-2010, 10:18 AM #318Apprentice
- Join Date
- Oct 2006
- Posts
- 82
I have been using Coolermaster real power pro 460W without any issue with 9600GT.
It has high efficiency rating. Better than even Corsair 450W.CPU - Intel E5500 (800 FSB)
M/B - Gigabyte G41MT-ES2L (Ver 1.0)
Ram - 2x 2GB Kingston 1333Mhz Value Ram
PSU - Cooler Master Real Power Pro 460W
GFX - Leadtek - 9600 GT
27-11-2010, 10:25 AM #319Right Off the Assembly Line
- Join Date
- Nov 2010
- Posts
- 21
well guys....
now some of you are telling me not to go for CX430....wat shud I do
But is CX400 still available in the market ? I heard that it has been taken out of the market ?
27-11-2010, 11:08 AM #320Wise Old Owl
- Join Date
- Sep 2010
- Posts
- 1,293
I think theitwares still has CX400 in stock.
27-11-2010, 11:21 AM #321
get cx400w
UPlay - Jas808, Steam ID - HD6950, TF2 Outpost - Link
Athlon II x4 635, CM Hyper 212 Evo, Gigabyte GA-880GM-UD2H, G.SKILL 6GB, Sapphire HD6950 1GB (Unlocked - HD6970), WDC 500GB Green, Corsair GS600, CM Elite 430, DELL ST2220L, X360 Controller, Logitech G400, Razor Goliathus Omega - Speed
HP Pavilion G6 2005AX - Genuine Windows 8 Pro, Samsung Galaxy Y Duos
27-11-2010, 11:55 AM #322
08-12-2010, 01:02 PM #323
Got a review on Corsair new GS600 PSU. Here is the link. As per the review it is recommended for a high end graphics card if you are in a tight budget.
It has very good electrical performance because of the advantage of PSH structure. Also load balancing or cross-load performance is very good, ripple control is also a good side.
Only issue is Heat and noise.AMD FX 8350|16 GB RipjawX 1873 MHz CL10 @ 1.6V MHz|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus|HCL Me Y2 Tab (rooted)
08-12-2010, 01:29 PM #324
Looks like a sliced-down-version-put-together-at-the-last-moment psu if you ask me. But then again, its made keeping gamers in mind and there is a significant market share so it make bit sense for people to purchase this but the price is something that has to be justified. They should have used better main capacitors and found a better work around for heat~noise. Its about time such psu comes where it gives the users the liberty to change the fans without voiding the warranty, especially in such stuff.
We should get units like Antec EA with proper distribution and service. Sadly, its one of those days when you want the good stuff, you just don't get it
08-12-2010, 05:35 PM #325
GS600 seems descent enough, hope some of the well known tech sites review it soon
09-12-2010, 12:37 AM #326Alpha Geek
- Join Date
- Jun 2007
- Posts
- 688
erm i have apc 500 back ups and ill be buying a seasonic 520 bronze ,will there be any problems?
i read on the 1st page of ths thread about active pfc problems.Last edited by aby geek; 09-12-2010 at 12:44 AM.
09-12-2010, 10:21 PM #327
go for 650 VA ups from APC
if budget doesnt allow ...then look out for microtek
09-12-2010, 10:52 PM #328
shouldn't be any problem till your PC (PSU mainly) consumes power below the amount the UPS able provide in blackout situations. if its more power needed, in case electricity goes, PC will shut down instantly.
also depends on what parts you add. if you run a simple Atom based CPU or a level d/l machine (i mean no HD6870 as you planning nor any S/B), than it won't create any problem & your aging UPS will provide so-so backup.
10-12-2010, 12:40 AM #329Alpha Geek
- Join Date
- Jun 2007
- Posts
- 688
waanh
cant go for 6870 then? jonny guru says seasonic 520 bronze will shut down at 300w load if the ups is on batteries and he had the apc 650 va ups.
my model is apc back ups es 500 how much i can sell it for and if i buy a new ups what should i buy 1kva or smthing else?
will a 6870 at idle too make the system shutdown and please tell me what if we consider upto 23" displays too.
my rig as you know is c2d e7500 on an asus p5qpl-am , so the only load causing pieces will be 6870 and a large display which iam yet to buy.
http://www.asus.com/product.aspx?P_I...9kT&templete=2
what phase design is my mobo ? is it 8+1 or not please tell me see the link .Last edited by aby geek; 12-12-2010 at 03:31 PM.
12-12-2010, 06:08 PM #330Alpha Geek
- Join Date
- Jun 2007
- Posts
- 688
hllo response please
Sapphire amd ati HD 7770 or sapphire amd ati HD 7770 overclocked edition??? - Graphics & Displays
Refback This thread18-03-2013, 11:30 PM -
18-03-2013, 05:41 PM
Refback This thread13-03-2013, 08:47 PM -
23-02-2013, 11:51 AM
21-02-2013, 08:52 PM
28-01-2013, 08:10 AM
What type of PSU is Compatable with the GTX 660 - Graphics-Cards - Graphic-Displays
Refback This thread25-01-2013, 02:54 PM -
Refback This thread25-01-2013, 02:39 PM -
24-01-2013, 08:32 AM
18-01-2013, 11:55 PM
18-01-2013, 05:14 PM
18-01-2013, 03:47 PM
WILL THIS GRAPHICS CARD WORK ON MY PC?? - Page 2 - Graphics-Cards - Graphic-Displays
Refback This thread03-01-2013, 05:42 PM -
Refback This thread03-01-2013, 05:17 PM -
31-12-2012, 07:29 PM
31-12-2012, 12:04 PM
08-11-2012, 01:50 PM
Weird Display Problem
Refback This thread01-08-2012, 10:17 PM -
My new PC! - Page 3
Refback This thread12-07-2012, 04:59 PM
power supply
By rajkiran in forum QnA (read only)Replies: 2Last Post: 22-05-2008, 11:27 PM -
Power Supply
By gmanog in forum Hardware Q&AReplies: 36Last Post: 05-02-2007, 01:19 AM -
Power supply
By kumarn_2004 in forum Hardware Q&AReplies: 1Last Post: 24-12-2006, 08:43 AM -
ULTIMATE GUIDE:eXtreme Power Supply Calculator v2.0
By Kiran.dks in forum QnA (read only)Replies: 4Last Post: 22-12-2006, 01:28 PM -
AMD 64 Power supply
By impetus in forum CPU / MotherboardsReplies: 4Last Post: 18-01-2005, 11:59 AM
LinkBack URL
About LinkBacks
