| Forum |
| PC Components / Configurations Questions about configurations go here. Strictly Buying Advice - No troubleshooting here. Go through each and every sticky thread of this section and other sections before posting. |
#1 (permalink) |
E8400 -- 8450 2GB RAM 800Mhz Transcend--1950 400 GB HDD Seagate--3150 Liteon 20X DVD RW drive--2150 Iball Cabinet stock 400W SMPS --1200 For the mobo i wud be buying a Asus P5GC MX 1333fsb with a HD 3450 for 2450 & 2050 respectively . Is the config okay cause i need to go low with the Mobo.
Girl = Time X Money . But Time = Money . i.e Girl = (Money)2 . Since money is root of all evil => Girl = Evil . So save your time & money and send all the GIRLS to me . |
#2 (permalink) |
Wandering In Tecno Land
Increase ur ram & power supply
If you want something better at a nice price tehn Opt for AMD else Intel is excellent
Born in Windows Die In Linux © 2009-10 All Rights Reserved. Learn Linux : www.linoob.com (Official WebSite) Last edited by Ecko; 14-08-2008 at 11:21 PM. Reason: Automerged Doublepost |
#3 (permalink) |
Dude the ram's at 800Mhz 2GB .stock 400 w should suffice. Nothing beats a combo of Intel Proccy & AMD graphx . AMD ????? wake up dude. Its 2008 not 2005
#4 (permalink) |
Violent serenity.
I don't think HD3850 is a good buy. Better get a Mercury 8600GT 256MB GDDR3 or the best option would be a 9600GT
I don't think 400W would suffice, get atleast a Cooler Master eXtreme Power 500W. Just some suggestions
Registered pwner of theists, noobs, posers and emos. |
#5 (permalink) |
^^ Are you sure that anything from Mercury is worth it . May be the things have changed at Mercury but they used to be worst than the cheap chinese non branded imports.
Well , i wont be using SLI or anything as such . If the stock gfx is good enough for my requirements then no gfx card . Though i seriously doubt that . Hence the 'HD 3450' . But i cant make out why the extra 100 W power for
#6 (permalink) |
Point Blanc
@Kpower, rakesh is right he really would not lead to change his PSU the stock iBall PSU will suffice his reqs. he is not opting for high power GPUs
@rakesh yesh Mercury or MSI GPU Kpower suggested is worth the price otherwise u can go for Palit/POV/XFX also, and he is refereing to 256MB DDR3 model of 8600GT. Think again of the mobo, I think you have not checked the specs of the mobo properly, u r buying 800 MHz FSB RAM for a 533 FSB mobo, n why r u going for older chipset mobo when u can easily get better chipset mobos in less than 3K |
#8 (permalink) |
Bond, Desi Bond!
1) Get MIS/Palit/eVGA 8600GT. Don't get XFX as it is runs very hot and never ever trust Mercury.
2) ASUS P5GC-MX is not 1333MHz FSB board. It's an 800MHz FSB board. Stay away from it if you want E8400. as it looks like you are on a budget, My config would be 1)Phenom X3 8450 for 5.5k 2) Gigabyte 780G mobo for 4.5k 3) 2Gb ddr2 800 ram for 1.8k 4) 400 GB HDD Seagate--3150 5) Liteon 20X DVD RW drive--2150 6) Iball Cabinet stock 400W SMPS --1200 7) HD 3850 for 8k or HD4850 for 10k This config will run most of the games at low settting and run Vista without any hiccup, thanks to the Dx10 onboard GPU. For Intel: 1) E8400 2) Abit IP35-E 3) nVidia 9500GT 8600 or HD3450 have become old and they will not be useful for long. Get 9500GT or HD4850 or HD3850.
My first blogspace: http://desiibond.blogspot.com |
#11 (permalink) | |
Instead of seagate go for Western Digital WD6400AAKS (640 GB) Its best bang for bucks. Instead of Transcend go for either G-Skill, Corsair, OCZ or team |
#12 (permalink) |
Violent serenity.
Kingston Value series
WD 640GB is the best HDD in the market right now cause it is retailing for 3.6k only.
#15 (permalink) |
FOR EVERYONE I HAVE BOUGHT ALL OF THE THINGS EXCEPT FOR MOBO & GFX CARD . ALSO I AM ON A SHOESTRING BUDGET FOR MOBO & GFX.... ***MAX 5000 OR LESS*** FOR BOTH .
Yeah i know 5000 is very less but due to my other purchases (mobile, Asus EEEPc etc)i am left with very little cash. Also i wud be upgrading mobo & gfx around 14 months from now. Getting XFX 630i is a good option but its not available here . Thanks for the suggestions guys.
#16 (permalink) | |
Gigabyte GA-EP43-DS3L Intel P43 Motherboard MSI P45 Neo3-FR Intel P45 Motherboard Gigabyte GA-EP45-DS3R Intel P45 Motherboard Asus P5Q Pro Intel P45 Motherboard DFI Lanparty DK X38-T2R Intel X38 Motherboard Asus P5E Deluxe Intel X48 Motherboard Gigabyte GA-X48-DS4 Intel X48 Motherboard Just to help you out: All of these motherboards have PCI-E 2.0 which may be useful for future GPU upgrades. If you don't need RAID, more than 6 SATA ports and only need semi-decent overclocking, check out the DS3L. If you need 8 SATA ports, RAID, 4 PCI slots, and legacy ports, then get the Neo3-Fr. If you don't need more than 6 SATA ports but want RAID, firewire, a second PCI-E x16 port, a second gigabit port, support for 16GB of RAM, optional eSATA, x8/x8 Crossfire, and high overclocks, then get the DS3R. If you like the DS3R but need 8 SATA ports, want an onboard pre-installed fast booting Linux setup, only need support for 8GB of RAM and don't need a second gigabit port, get the Asus P5Q Pro. If you want Crossfire with full x16/x16 bandwidth, get the Lanparty DK X38. Do note that the Asus website can be slow sometimes. |
#17 (permalink) |
^^^^ Any of the motherboards that u've mentioned don't come within 5000 bucks . Even at newegg all are more then 100$ .
I can't extend my budget by even 100 bucks. Just to repeat I need no RAID , no crossfire , no overclock , no nothing . I just need a barebones MicroATX ( as it wud be cheaper than a ATX) . And a barebones graphics card that can play games upto the year 2006 max. and both of them within 5000 any other things in that price wud be a Luxury . Just so that you know I wud be upgrading to MSI 45 Neo 14-20 months from now .
#19 (permalink) |
^^ A very good board but no dual channel support . Has a very good IGP for its price though . Also Is 8400GS 256 MB DDR2 better than the recently launched HD 3450 256 MB DDR2.
Thanks for the help guys .Appreciate it . What about my original suggestion of P5GC MX 1333 . Here's the specs for it http://in.asus.com/products.aspx?l1=...68&modelmenu=1 .
#20 (permalink) |
Point Blanc
@rakesh the mobo you are considering is not a proper for your proccy and RAM, until and unless you OC it.
neither is ASUS P5N-MX suitable for the proccy and RAM I suggest you consider good onboard graphics mobo based on nVidia 630i chipset like from XFX 630 (price 3.5K), Palit N73PV Motherboard(less than 3K), they would be enough for old playing games, saves your money also, so that if you really wanna go for any GPU u can get one whichever you think is good. 7150 onboard GPU is much better than intel x3100 onboard GPU. In 8400 and 3450, I would say 3450 is better choice. |
#21 (permalink) |
Thanks acewin , its most likely to be between XFX 630i & P5GC MX if i don't get any other mobo .
wud it cause any probs if i overclock the FSB . Coz i will be keeping the proccy for a really long time . P.S. : Damn i wish i hadn't paid off my gf's bills.
#22 (permalink) |
Point Blanc
you really shouldnt have done that for the gf.
The Asus mobo is OC mobo so you can do that, but then it has 610i chipset. So as per my suggestion it would not be worth to OC when you are already getting better stable 630i mobos without OCing in same price. I would say get the Palit mobo. You would be just paying extra for no benefit. |
#23 (permalink) |
damn busy...
Get a gigabyte g31m-s2l and a 8400gs . Total 4.7k max
MSI GX660 with ATI 5870 Dell Studio 15(1555) 1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+ www.techjunkiez.com |
#24 (permalink) |
IronMan; Ready to Roll...
Man, get a good Onboard solution; what do you want? you want to play games that were released till 2006, isnt it? Just put all your money on a motherboard which has a good onboard. i think you can find a Zotac GF8200 or something like that. Later you wont have to upgrade your mobo, just adding a GFX card will do, got it?
Aluminum MacBook 2.0GHz Collector's Edition Windows Box: 2.26G P4, 1GiB RAM, 320GB SATA + 80GB PATA HDD, Nvidia FX5200 AOC Fovi F22 iPod Touch 16GiB, HTC Gene, Moto W230, Sansa Express |
#26 (permalink) |
Naah we have been doing that for a while now . this month i went a little overboard with my purchases the Open Moko Neo Runner . & the Asus 901 EEEPc. And also the PC components . So no money for mobo . for GFX was looking at Sapphire HD 3470 256MB DDR3 or Asus HD 3450 256 MB DDR2 anyways (never wud have paid any penny more than 2500 for GFX) no 8400's or 8600's for me (too old) . .
XFX wud be fine but it wud have made no sense for buying the 6xx series mobo ( no dual channel RAM ) if not for the CREDIT CRUNCH. Single channel wud make no difference but still ..... I wud be buying monday evening . Not sure if XFX is available as no service by XFX folks here at my place. Will check out and let you know . UPDATE :: XFX 630i is not available its a HIGH END mobo they say as its a NVidia Chipset . it will take time after ordering. Also Palit is not available . Should i order the Palit N73PV online . Palit has mixed reviews on the net and it basically caters to the entry level . What about their after sales service. Also Sapphire HD 3470 is not available anywhere in the country so i wud be buying a Asus EAH3450 256MB look here http://www.asus.com/products.aspx?l1...51&modelmenu=2 or a 128 MB DDR3 with a higher clock http://www.asus.com/products.aspx?l1...61&modelmenu=2
Girl = Time X Money . But Time = Money . i.e Girl = (Money)2 . Since money is root of all evil => Girl = Evil . So save your time & money and send all the GIRLS to me . Last edited by mehra.rakesh; 16-08-2008 at 08:41 PM. Reason: Automerged Doublepost |
#27 (permalink) |
hey guys ... Any suggestions . I am desperate . So far its between XFX 630i or Zotac N73PV ( i think Palit & Zotac are the same company )..
If not possible i cud buy a mobo with a good onboard gfx for 5k max .. PLZZZZZ KEEP THOSE SUGGESTIONS COMING. THANX
#29 (permalink) |
I dont think Palit and Zotac are the same company...
The Zotac one would do just fine... But I stay with my previous opinion; get a goo onboard solution capable of playing HD smoothly; Trust me; you'll be getting a good mobo as well as wont have to sell anything next time you buy a GFX card. [Offtopic] @mehra.rakesh .. Can you put up a review of the OpenMoko set that you bought. Im in love with it but i don't know how it performs in real world? Could you do that? @KPowerMania .. grr.. You stole my Location? For your profile?
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Plz suggest new config.. (update on already referred config) | xsreality | PC Components / Configurations | 48 | 02-06-2007 04:08 PM |
| See my config | Devrathnd | PC Components / Configurations | 10 | 06-05-2007 10:04 AM |
| how about my config? | spidey | QnA (read only) | 11 | 10-07-2005 12:17 PM |
| config | parimal | QnA (read only) | 2 | 30-06-2005 10:41 PM |
| What about this config? | anilthomas26 | QnA (read only) | 6 | 26-06-2005 09:29 PM |
