Go Back   Digit Technology Discussion Forum > Hardware > PC Components / Configurations
PC Components / Configurations Questions about configurations go here. Strictly Buying Advice - No troubleshooting here. Go through each and every sticky thread of this section and other sections before posting.
Old 07-04-2008, 10:44 AM   #1 (permalink)
Default Please Suggest Config -- Bangalore (Intel Q6600 Price Cuts April 20th)
Processor -- 1.E8400 or 2.Q6600
Ram -- 2GB x 2 Transcend DDR2 800
Motherboard -- Abit IP35-E
G.Card -- Nvidia 8600GT(512 MB/ 1GB DDR2) Any brand recommendations ?
HDD -- WD Caviar WD5000AAKS (optional)
DVD Writer -- Sony/Samsung
Cabinet + SMPS -- Some Zebronics
NO monitor,NO KB/M, NO Speakers
Any Improvements ? Price MAX == 35K
I am not much into gaming but i need a high performance (not high gaming performance) system. Please give your valuable suggestions.....
So wait till April 20th ?
Jayanth.M.P is offline
Old 07-04-2008, 10:53 AM   #2 (permalink)
At Hell's Disq
hellgate's Avatar
Default Re: Please Suggest Config -- Bangalore
Processor -> E8400 ->8.3k
Ram -> 2GB x 2 DDR2 800 -> 4k
Motherboard -> IP35-E -> 5.6k
GPU -> MSI 8800GT 512MB -> 12k
DVD-RW -> Samsung -> 1.1k
Cabinet -> 1.5-2k
SMPS -> CM 690W - 3.9k
Total comes to 36.9k.u can always save 2k by getting 2*1GB DDR2 now and lateron add another 2GB.
hellgate is offline
Old 07-04-2008, 10:55 AM   #3 (permalink)
=--=l33t=--=
ring_wraith's Avatar
Cabinet -> 1.5-2k
+1, but get 2 gigs of RAM. You don't need 4, and it's incompatible with 32 bit OSes.
Homer: God bless those pagans.
ring_wraith is offline
Old 07-04-2008, 11:08 AM   #4 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
if its a high performance PC for some 3d \ other workstation work go with a Quad core only , forget the rest
Other part of the config as hellgate said..
and go for a CM 330 elite cabby for that price range
and 4gb ram works with both XP and Vista 32bit..its only that in XP it will show around 3gb ram , which is normal.
Apple Macbook Pro 17
nish_higher is offline
Old 07-04-2008, 11:20 AM   #5 (permalink)
Point Blanc
32 bit OS do not work well with 4 GB RAM (better say more than 3 GB RAM).
Even the performance can go down with $GB XP-32.
acewin is offline
Old 07-04-2008, 12:10 PM   #6 (permalink)
Alter Bridge=GOD
they do work and theres no negative impact on performance
here's my own screenie with 4gb ram-
Old 07-04-2008, 12:45 PM   #7 (permalink)
Cabinet -> 1.5-2k
8800GT is way to high end graphics card for my needs....i dont do too much of rendering work.
My main day to day apps are:
UT3 (10-15 mins) to Warm up
Photoshop CS3
Flash CS3
Visual Studio 2008
Movies (Lot of WinRAR)
So i am not looking for a card as powerful as 8800GT, Processor Q6600 is what i am bending towards. I prefer having a lot of RAM, 4GB or 8GB something like that......will having more than 4 GB of RAM cause performance problems ? (bcoz of software ?)
Hey anyone knows when Q9450 Series will be released by intel ?
I also heard that Intel is cutting the price of processors (65 nm) by some 50% form 20th of april. Anyone heard this ?
http://www.nordichardware.com/news,7353.html
Old 07-04-2008, 01:15 PM   #8 (permalink)
Commander in Chief
QwertyManiac's Avatar
Get 8600GT if that's the case, its around half that price. The remaining value can be added for the RAM. RAM > 4 GB would be good and wouldn't give issues, but its wise to use a 64 bit OS along with it.
Harsh J
www.harshj.com
QwertyManiac is offline
Please Suggest A Safe And Budget Hotel in Bangalore sourav123 Chit-Chat 5 11-02-2008 07:20 PM
suggest me a shop in bangalore to buy RKR E6 Baker Buying Advice 2 07-12-2007 01:47 PM
Suggest a PSU for this config nightcrawler PC Components / Configurations 5 05-10-2007 12:24 AM
Plz suggest new config.. (update on already referred config) xsreality PC Components / Configurations 48 02-06-2007 04:08 PM
HELP!!! Buying a Pc in Bangalore HELP!!!Need config n price bunny01in QnA (read only) 4 23-09-2005 03:56 PM
