Go Back   Digit Technology Discussion Forum > Hardware > PC Components / Configurations
PC Components / Configurations Questions about configurations go here. Strictly Buying Advice - No troubleshooting here. Go through each and every sticky thread of this section and other sections before posting.
Old 14-01-2008, 07:48 PM   #1 (permalink)
Default Need help regarding configuration!
Hi!
I'm going to go in for a completely new PC within a budget of 30k. Here is the stuff that I have decided upon, it would be wonderful if you guys can point out any discrepancies within this configuration. Also please suggest a good cabinet and if I should go in for a separate SMPS.
Intel C2D E6750 2.66Ghz
Abit Fatal1ty FP-IN9 SLI or XFX 650i Ultra
2 * Kingston 512 DDR2 800Mhz
WD 320GB
XFX 256Mb DDR3 8600GT
Samsung CRT 17"
Lite-On LightScribe 20x DVD writer
Creative Speakers 2.1
Logitec Combo (Keyboard + Mouse)
Thanks!
hirohit is offline
Old 14-01-2008, 08:04 PM   #2 (permalink)
New
New's Avatar
Default Re: Need help regarding configuration!
Zebronics Antibiotics is the good cabinet for you..
New is offline
Old 14-01-2008, 08:40 PM   #3 (permalink)
Sangeet Premi
2kewl's Avatar
Try to get a 19" LCD, if possible.
2kewl is offline
Old 14-01-2008, 09:34 PM   #4 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Try to fit in a 19 inch lcd into ur budget
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
CHK my Pc Configuration Pravas PC Components / Configurations 13 07-04-2007 07:25 PM
Configuration... bajaj151 PC Components / Configurations 1 18-03-2007 01:19 PM
best configuration at 32k pradipudhaya PC Components / Configurations 3 15-03-2007 03:04 AM
configuration karmanya PC Components / Configurations 5 16-09-2006 09:44 PM
what is best configuration prem QnA (read only) 12 23-05-2005 07:30 PM
