Go Back   Digit Technology Discussion Forum > Hardware > PC Components / Configurations
PC Components / Configurations Questions about configurations go here. Strictly Buying Advice - No troubleshooting here. Go through each and every sticky thread of this section and other sections before posting.
Old 04-12-2007, 07:28 AM   #31 (permalink)
High without substance...
chicha's Avatar
Default Re: is this system config ok for games
Originally Posted by desiibond
There was GPU roundup in October 2007 digit issue.
Found this awesome card ASUS EN8600GT. This was damn fast and churned more frames than 8600GTS, which were 10k+. The price listed in the magazine for EN8600GT was Rs. 8,800. You should be able to get this card for 6.5-7k easily.
There is one more model ASUS EN8600GT Silent (without fan, has silent heatpipe). This one is nowhere near to the one mentioned above.
If you can get ASUS EN8600GT with 512MB of GDDR3 RAM for less than 7k, go for it. You will definitely get stellar performace/price ratio
yes i know DDR2 and DDR3, but thank you anyway.
i wanted to know the price differnce between a 256MB and 512MB DDR3.
i looked many places for this perticular model, i too read the issue you are talking about. In bangalore i looked, in some places but did not get it. i will look again today and post.
thanks a lot
I am Acrophobic, Entomophobic, Melissophobic. :).
chicha is offline
Old 04-12-2007, 09:07 AM   #32 (permalink)
Bond, Desi Bond!
desiibond's Avatar
512MB 8600GT (XFX/ASUS) is not available at SP Road and owner of Railton said that he will get it by next month. He said it's not yet released in Bangalore.
desiibond is offline
Old 05-12-2007, 12:52 AM   #33 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
thanks a lot
The diff. between 512 and 256 MB versions og 8600 Gt is hardly 1500/-
keith_j_snyder2 is offline
windows/system 32/ config/system files corrupted or missing ? mkmkmk Software Q&A 9 02-04-2009 02:55 PM
how is this system config... chicha PC Components / Configurations 2 28-11-2007 06:22 PM
Is this config good enough to play games??? rajasekharan PC Components / Configurations 12 06-12-2006 03:13 PM
Config On 50k System Needed m-jeri QnA (read only) 2 01-10-2005 08:30 PM
My System Box Config.... debasis_7012005 QnA (read only) 4 22-04-2005 07:23 PM
